Gyro reverse switch problem v450
- saad khan
24 Feb 2015 16:38 #29078
by saad khan
Gyro reverse switch problem v450 was created by saad khan
I have this little confusion. Whenever I tilt manually the heli in the right direction, the swash plate suddenly moves towards the right(very small extent) and then goes back to left(level position) slowly . so is this correct
or
When I tilt the heli in the right direction, the swash plate suddenly moves towards the left(very small extent,and to level position) and then goes back to right position slowly. so kindly tell me which one is correct.
Same is problem with elevator.
Kindly help me..
or
Kindly help me..
- Block137
25 Feb 2015 03:23 #29085
by Block137
Replied by Block137 on topic Gyro reverse switch problem v450
Maybe these video can help you?
note: those are not my video.
I just search on YouTube because explaining by words can be confusing.
- saad khan
25 Feb 2015 06:22 #29089
by saad khan
Replied by saad khan on topic Gyro reverse switch problem v450
Yes I checked it by walkera rx 2702v is not working exactly like that... It goes slowly not to actively in the opposite direction of the movement.
- Block137
25 Feb 2015 12:16 #29095
by Block137
How about responses to transmitter sticks?
Is it slow or doesn't move far?
Do servos got hot?
just to be sure...have you tried turning Gain knobs?
and also servos travel setup?
Do servos got hot?
- saad khan
25 Feb 2015 15:09 #29102
by saad khan
The response to transmitter stick is okay. it moves fast on transmitter stick. Servos are okay, doesnt get hot.
yes travel setup and gain knobs are okay.gain knob just change the sensitivity.
Problem is that servo response is slow to gyro sensor. i-e moves slow in opposite direction to counter the changing in position.
You can check in video..
- saad khan
25 Feb 2015 15:16 #29104
by saad khan
check this video
- Block137
26 Feb 2015 03:47 #29121
by Block137
If the direction is already correct I suggest you hover it.
Turn the gain full clockwise for aileron knob and middle for elevator knob.
Test by giving it a fast Nose-down(forward elevator)
if there's no oscillation, turn elevator knob clockwise a little
repeat. . . . .
1st case: your heli oscillate at some point then your gyro is fine.
2nd case: you hit knob limit without oscillation then your 2702 might have a problem.
repeat. . . . .
- saad khan
26 Feb 2015 09:05 #29125
by saad khan
okay Thanks
Time to create page: 0.176 seconds
- Gyro reverse switch problem v450
