Gyro reverse switch problem v450
24 Feb 2015 16:38 #29078 by saad khan
Gyro reverse switch problem v450 was created by saad khan
I have this little confusion. Whenever I tilt manually the heli in the right direction, the swash plate suddenly moves towards the right(very small extent) and then goes back to left(level position) slowly . so is this correct
or
When I tilt the heli in the right direction, the swash plate suddenly moves towards the left(very small extent,and to level position) and then goes back to right position slowly. so kindly tell me which one is correct.
Same is problem with elevator.
Kindly help me..
25 Feb 2015 03:23 #29085 by Block137
Replied by Block137 on topic Gyro reverse switch problem v450
Maybe these video can help you?
note: those are not my video.
I just search on YouTube because explaining by words can be confusing.
25 Feb 2015 06:22 #29089 by saad khan
Replied by saad khan on topic Gyro reverse switch problem v450
Yes I checked it by walkera rx 2702v is not working exactly like that... It goes slowly not to actively in the opposite direction of the movement.
25 Feb 2015 12:16 #29095 by Block137
How about responses to transmitter sticks?
Is it slow or doesn't move far?
Do servos got hot?
just to be sure...have you tried turning Gain knobs?
and also servos travel setup?
25 Feb 2015 15:09 #29102 by saad khan
The response to transmitter stick is okay. it moves fast on transmitter stick. Servos are okay, doesnt get hot.
yes travel setup and gain knobs are okay.gain knob just change the sensitivity.
Problem is that servo response is slow to gyro sensor. i-e moves slow in opposite direction to counter the changing in position.
You can check in video..
25 Feb 2015 15:16 #29104 by saad khan
check this video
26 Feb 2015 03:47 #29121 by Block137
If the direction is already correct I suggest you hover it.
Turn the gain full clockwise for aileron knob and middle for elevator knob.
Test by giving it a fast Nose-down(forward elevator)
if there's no oscillation, turn elevator knob clockwise a little
repeat. . . . .
1st case: your heli oscillate at some point then your gyro is fine.
2nd case: you hit knob limit without oscillation then your 2702 might have a problem.
26 Feb 2015 09:05 #29125 by saad khan
okay Thanks
Time to create page: 0.355 seconds
