ESKY150 Protocol and DEVO 6/8S
25 Feb 2015 17:51 #29113 by dado099
ESKY150 Protocol and DEVO 6/8S was created by dado099
I have installed nRF24L01 module inside my Devo 6S and it's correctly working.
I have also installed las nightly build 2015 02 21.
Now I have active the ESKY150 protocol (withouth the asterisk).
I try to bind with an E-SKY F150, but without success.
When I press re-init button nothing happens at all.
I searched the forum and I found that only a success with this protocol is reported with a Devo 10.
So I was asking:
is ESKY150 really implemented also for Devo 6/8 or am I loosing my time ?
It would be interesting to implement this protocol beacause it seems that E-SKY will only use this from now on.
Thank you very much.
26 Feb 2015 05:14 #29122 by victzh
Replied by victzh on topic ESKY150 Protocol and DEVO 6/8S
Sorry, I have neither E-Sky F150 nor Devo 6S. I reversed the protocol "by ear" - SeByDocKy's SPI dumps and try outs of my code.
In theory, there should not be any difference between transmitter's handling of the protocol.
How do you know that the module is working correctly?
26 Feb 2015 07:10 #29123 by dado099
Replied by dado099 on topic ESKY150 Protocol and DEVO 6/8S
Thank you victzh for the reply.
I suppose the module is working because I have no more asterisk in front of it.
Is that enough ?
26 Feb 2015 19:43 #29138 by victzh
You'd better check that it works with some other nRF24-based protocol, not only E-Sky 150.
No star means the module is configured in hardware.ini file, that's it.
27 Feb 2015 00:23 #29153 by hexfet
Replied by hexfet on topic ESKY150 Protocol and DEVO 6/8S
victzh wrote: No star means the module is configured in hardware.ini file, that's it.
If the 2015-02-21 build is from the deviationtx repo it includes the code that checks communication with the nRF chip. No guarantee it's working as a radio, but writing/reading to it is working if no "Missing Module" screen is displayed. I think that's in the PB nightly as well.
28 Feb 2015 00:02 #29187 by victzh
Anyways, the best test is another protocol working with the module.
20 Mar 2015 13:10 #29927 by dado099
Wanna start a survey:
Anybody success with protocol ESKY150 ?
If yes, please specify which Devo TX radio and wich nightly build version.
Thank you very much for any feedback.
Dado
20 Mar 2015 14:34 #29933 by SeByDocKy
Replied by SeByDocKy on topic ESKY150 Protocol and DEVO 6/8S
What I learnt, there is a "binding" procedure with the radio... I will try to capture some new SPI data one day
21 Mar 2015 10:17 #29986 by linus23
Replied by linus23 on topic ESKY150 Protocol and DEVO 6/8S
Survey input.
Devo 7e, nRF and A7 modules, TX working fine with, V911, V966, V977, Orange RX 100/V-bar, Cheerson CX-30, so all modules working as expected.
Deviation FW version devo7e-v4.01-9022e68.
No response/reaction from TX trying bind Esky 150.
I'd be happy to flash and try any build suggested.
08 May 2016 16:25 #48047 by dado099
Hi All,
is there any update on f150 protocol ?
If it is still dead (as I believe) why don't remove it from possible protocol choiche ?
If you leave it you will make loose a lot of time to whom trying to make it work.
Thank you
18 May 2016 02:02 #48617 by victzh
SeBy, is this binding for F150 only, or for 150 as well? Can you shake the dust from your model and check? :-)
07 Jun 2016 15:08 #50094 by SonELin
Replied by SonELin on topic ESKY150 Protocol and DEVO 6/8S
I agree !
The Esky150 protocol is not binding no matter how ~
I have tried many version of Deviation and many kind of binding ,it still doesn't work~
There is not too much people have this helicopter in China,so I came here to look for answers.
hope victzh can solve it~thanks!
I'm not very good at English~: )
07 Jun 2016 15:44 #50100 by dado099
Nice !
second person in the world who has esky 150 !
The stock tx is rubbish, please help us !
07 Jun 2016 15:48 #50101 by victzh
How? I don't have it. Can you solder to TX and capture SPI traces?
07 Jun 2016 15:52 #50102 by dado099
Doesn't SeBy has one as you told ?
I don't know how to capture SPI traces
07 Jun 2016 16:11 #50105 by victzh
The problem is it's SeBy's model I did my reverse engineering on - remotely, over the ocean :-) So it's probably still working for him - they must have changed protocol since I did this.
There are instructions published at www.deviationtx.com/forum/protocol-devel...95-spi-capture-guide .
19 Dec 2016 11:04 #56975 by Käseknigger
Replied by Käseknigger on topic ESKY150 Protocol and DEVO 6/8S
Just as an update as I recently recorded the binding process for my 150X here:
www.deviationtx.com/forum/6-general-disc...ch-protocol?start=20
The current implementation of the esky 150 protocol doesn't have the binding part included. Therefore it probably only worked for Seby's model, as he was the one contributing his SPI data. So only his model is bound to this TX_ID.
@victzh:
Did you program the esky 150 protocol?
As I would like to update it, but there are a few things I don't get.
E.g. How did you get to this channel selection code out of the TX_ID, with even a random scrambled devo id, not using his original TX_ID???
E.g. SeBy's TX uses the channels 22 and 4A (at least that's what it seems from the code). My TX has a completely different TX_ID but still uses the channels 22 and 4A. So I'm wondering...
19 Dec 2016 11:11 #56976 by dado099
Hi Kaseknigger,
great discovery !
If you see my old posts it's about one year that I insist that ESKY150 protocol only works on SeBy heli all over world !
But nobody took care of this, I also proposed to delete the protocol to save memory......
Hope someone will implement a working one for ALL !
19 Dec 2016 12:25 - 19 Dec 2016 12:48 #56978 by Käseknigger
Yes, I'm looking forward to update it, also adding the additional channels.
Probably we should then rename it into something like ESKY_NEW, and not 150, as the TXs seem to work for all new ESKY stuff.
I'm still just puzzled, how the channel selection works.
Strangely, the first 2 bytes in every data packet declare on which channels the data gets sent. But why including this in every data packet?
Or does the RX scan just all possible channels until it finds one and then uses these channels???
For me that's kinda the only reasonable explanation...
For if the channels would be TX_ID specific, then why declare them in every data packet?
That would also explain why my TX sends on the same channels as SeBy's. So it would seem stock TXs all send on the same channels, independent of the TX_ID.
But for Devo one could make it send on any channel one wants independent of the TX_ID.
Last edit: 19 Dec 2016 12:48 by Käseknigger.
Time to create page: 0.153 seconds
