3 way switch links...
- stepels
02 Mar 2015 09:34 #29262
by stepels
3 way switch links... was created by stepels
Hi all, I want to put an extra link inside a mix switch, MIX switch on a devo 10. Ive got a ikon fbl unit with auto level/bailout function and i want to link in to pitch so when i hit the switch for bailout it automatically puts in + pitch as well. Im using the mix switch for the 3 modes in the ikon and mix 0 is set for the bailout. Can anyone help with the setting up of this????
Cheers
Cheers
02 Mar 2015 10:00 #29263
Replied by FDR on topic 3 way switch links...
You can use any MIX switch states to select a different pitch curve if you use the complex mixer on your pitch channel:
Set up two or more complex mixer pages, make them to replace each other with the mux type, and set the switch to the desired MIX switch state...
- stepels
02 Mar 2015 21:57 #29275
by stepels
Replied by stepels on topic 3 way switch links...
Cheers FDR, here's what have on my devo 10 that works at the moment,
ch-1 thr complex
ch-2 ail cyclic 1
ch-3 ele cyclic 2
ch-4 rud expo&dr rud fmod1 fmod2
ch-5 gear simple (gyro) gear0
ch-6 pit cyclic 3
ch-7 (ikon mode) complex mix0
cyc-ail expo&dr ail fmod1 fmod2
cyc-ele expo&dr ele fmod1 fmod2
cyc-col complex thr
What might i need to change if anything? All this a little greek to me! lol
ch-1 thr complex
ch-2 ail cyclic 1
ch-3 ele cyclic 2
ch-6 pit cyclic 3
cyc-col complex thr
03 Mar 2015 06:00 #29280
First, do you really need CCPM? What splash plate setting do you have?
If you need the CCPM mixing, then you should implement the different pitch curves in the cyc-col virtual channel.
If not, you can simplify the whole setup, and the pitch would be on Ch6.
- stepels
06 Mar 2015 08:34 #29391
by stepels
Thanks for all your help but i have just figured it out with the stock setup by adding another mixer in the cyc-col complex settings. Will write in my settings for maybe help someone else. Again thank you!!!!
- Thomas.Heiss
07 Mar 2015 09:09 #29424
by Thomas.Heiss
Replied by Thomas.Heiss on topic 3 way switch links...
You want to achieve the same like me:
www.deviationtx.com/forum/3-feedback-que...200qx-rescue-bailout
Time to create page: 0.070 seconds
- 3 way switch links...
