Master CP Poor servo responce
04 Mar 2015 18:18 #29330 by Condor
Master CP Poor servo responce was created by Condor
This helicopter has always had this problem, even after changing the Rx and ESC. I have downloaded various ini files all give me the same result, namely:
Collective pitch responds as normal at a rate that keeps up with stick inputs. Cyclic is very sluggish and rough, if I hold full cyclic stick the servo slowly and jittery the servo moves more. If I add more Collective the problem gets worse.When I roll the Heli while holding it the cyclic response to the Giro is fast and accurate. Can any body help, as am close to putting Rx gear from another Heli to solve this.
Time to create page: 0.317 seconds
