Walkera Dfuse usb tool?
- Skysurfer
09 Mar 2015 04:45 #29475
by Skysurfer
Walkera Dfuse usb tool? was created by Skysurfer
Where can one get this tool?Walkera Dfuse usb tool? any links?
- Skysurfer
09 Mar 2015 11:51 #29489
by Skysurfer
Replied by Skysurfer on topic Walkera Dfuse usb tool?
Thank you FDR, finally getting up enough guts to try this on my Devo 10!
- RedSleds
13 Apr 2015 23:48 - 14 Apr 2015 00:08 #31140
by RedSleds
Replied by RedSleds on topic Which version to use?!
Another puzzling question!
The Deviation Firmware Manual for the DEVO 7E & 10 links directly to Walkera for the DfuSe USB Tool download and it downloads v2.0
I found a download from the German's Walkera-Fans website that is v2.31 Not sure if it is allowed to be linked here, or not, so I won't until a Moderator or the Admin says it's OK to do so.
I am brand new to Deviationtx, so I don't want to screw this up. So, these questions go out to any more experienced members here:
1. Which one would you install?
2. Does it really matter which version gets used?
3. I am running Windows 8.1, and have read that some are having trouble with 8.1 and having to run on an XP box to get it done. Will v2.31 eliminate this problem?
Last edit: 14 Apr 2015 00:08 by RedSleds.
- justyn07
14 Apr 2015 00:02 #31141
by justyn07
Replied by justyn07 on topic Walkera Dfuse usb tool?
i have windows 8.1 and no problem.
- RedSleds
14 Apr 2015 00:05 - 14 Apr 2015 01:51 #31144
by RedSleds
Replied by RedSleds on topic Walkera Dfuse usb tool?
It's a non-issue, I guess. I used the dfuse v2.0 with my Windows 8.1 OS box, and everything went well.
The display contrast was kind of low when I first fired up after deviation was complete, so upped the contrast and backlight values so I could see things a little better. Surfed the menus a bit and calibrated the sticks.
Yay!!! First step is done. Now I need to get the modules that I want to install and go to work with the soldering iron after I read up on it a little more and decide how to go about it.
Last edit: 14 Apr 2015 01:51 by RedSleds.
- digitracer
19 Feb 2016 15:56 #43315
by digitracer
Replied by digitracer on topic Walkera Dfuse usb tool?
Since Walkera doesn't support helis anymore the above given link for dfue is meawhile dead.. I found a new working one @:
www.iuasinc.com/content/DevoDfuse%20USBUpgradeTools.zip
Greets
Greets
19 Feb 2016 16:10 #43317
Replied by FDR on topic Walkera Dfuse usb tool?
Here you can find more:
drive.google.com/folderview?id=0B6SupsT8...jTkZvTFpPU1MxTDRGTnc
It is linked in the Links menu on the left...
- digitracer
19 Feb 2016 18:42 #43324
by digitracer
Surely much closer, - especially for freqeuent users - just me who could not find that tree in the wood.
Btw you can find that non working link in the manuals as well.
Greets
Greets
19 Feb 2016 18:45 #43325
You are right, that should be fixed...
- Tamis
30 Mar 2016 17:32 - 30 Mar 2016 17:45 #45451
by Tamis
Replied by Tamis on topic Walkera Dfuse usb tool?
just received my Devo 10 today. I wish to flash the firmware but I saw that the manual recommends to take v2.0 while Dfuse USB Upgrade Tools 2.31.zip is available.
Do I use the last version ?
The manual says "Normally you should use the latest one." It's the normally that worries me, I wouldn't want to be the exception...
Thanks a lot
Cheers
Thanks a lot
Cheers
Last edit: 30 Mar 2016 17:45 by Tamis.
- RedSleds
30 Mar 2016 20:25 - 30 Mar 2016 21:05 #45462
by RedSleds
I used Walkera DfuSe v2.0 with Windows 8.1, also I used a USB 2.0 port(black) on my PC to connect the Tx. I didn't try it with USB 3.0 port(blue).
You also can use the Deviation Uploader Utility, instead of using the Walkera DfuSe tool.
There are instructions on how to use both of these in the User Manuals that are under the Main Menu column at the left.
I plan on using the Deviation Uploader next time that I need to flash my DEVO 10.
Last edit: 30 Mar 2016 21:05 by RedSleds.
- TomPeer
31 Mar 2016 10:04 #45493
by TomPeer
Replied by TomPeer on topic Walkera Dfuse usb tool?
I use dfuse 2.31.
Works fine.
Tom
Works fine.
Tom
- bmw2444
03 Apr 2016 22:01 #45743
by bmw2444
Replied by bmw2444 on topic Walkera Dfuse usb tool?
Help. Cant get pc to recognize devo 10. Using windows 10. HP pc with amd a6 processor. 64 bit. I'm getting error code 43. It seems like a driver or compatibility problem. What's strange is the it was actually working once upon a time.
- Arnold
03 Apr 2016 23:12 - 03 Apr 2016 23:13 #45744
by Arnold
Get the driver installer that PB wrote some time ago for both Walker's Dfuse tool and the Deviation Uploader app from this location:
www.deviationtx.com/downloads-new/category/161-dfu-usb-tool
I recommend using the Uploader as well, rather than the Dfuse. Can be used for any version of Deviation as well as Walkera's firmware if you need to fall back for any reason.
Not sure about Win 10, but worth a shot. Report back with your results, please.
Replied by Arnold on topic Walkera Dfuse usb tool?
bmw2444 wrote: Help. Cant get pc to recognize devo 10. Using windows 10. HP pc with amd a6 processor. 64 bit. I'm getting error code 43. It seems like a driver or compatibility problem. What's strange is the it was actually working once upon a time.
Last edit: 03 Apr 2016 23:13 by Arnold.
- bmw2444
04 Apr 2016 11:50 #45776
by bmw2444
Unfortunately still not able to get pc to recognize Tx. It seems very much like a driver issue because it worked without problem on my pc running windows 10. Don't know if I inadvertently did something to lose the ability to access USB or Dfuse modes. I am not an expert with pc lingo etc. but can comprehend simple directions. Not to sound too simplistic is there a step by step instructions for up loader /Dfuse and which versions to use for each operating system? A Deviation for dummies? Just to ensure I'm not overlooking anything. Also I am wondering as a last ditch effort is there a way of accessing the info manually by taking the module out and connecting to pc or something to reflash and start over. Could it have been possibly an error during the initial install? Also was able to access My wife's laptop which has windows 8 same results. I actually went back to windows 7 on my pc to see if it would work only to similar results. The only difference was that if I manual searched for a driver it would install device for a few seconds request a restart for changes to take effect. After restarting it would not recognize device. I went back inside of Tx to see if the usb soldering connections we faulty to find that they were intact and solid. Someone please help me. Lol my wife s going crazy over this.
- bmw2444
04 Apr 2016 11:52 #45777
by bmw2444
I would also like to thank everyone sincerely for their support in this manner the deviation community is great I would also like to add.
- Arnold
04 Apr 2016 15:40 - 04 Apr 2016 15:46 #45784
by Arnold
www.deviationtx.com/forum/6-general-discussions/5608-12s#45239
That thread contains step-by-step guidance I provided to another user recently. He's using a Devo 12, but those steps are fine for all Devos.
Last edit: 04 Apr 2016 15:46 by Arnold.
- bmw2444
04 Apr 2016 17:33 #45786
by bmw2444
Thanks once again I will give it a go.
- bmw2444
05 Apr 2016 01:42 #45810
by bmw2444
Great news was able to fix the problem with getting my pc to recognize Tx. It turns out that the STM32zip file contains something that corrected the issue with the driver. Working fine now Thanks again to all of my deviation brothers and sisters.
Time to create page: 0.314 seconds
- Walkera Dfuse usb tool?
