Flipping a Hubsan X4 with Deviation
- Tryptych
10 Mar 2015 10:59 - 10 Mar 2015 11:08 #29522
by Tryptych
Flipping a Hubsan X4 with Deviation was created by Tryptych
Newbie question! I'm wondering if Deviation can make my quads (Hubsan X4 and Proto X SLT) use their flip features with the push of a button/switch?
Last edit: 10 Mar 2015 11:08 by Tryptych.
10 Mar 2015 20:39 #29532
Replied by mwm on topic Flipping a Hubsan X4 with Deviation
Can you bind the Proto X SLT? Mine doesn't go into bind mode properly, so I've got to wait until late April to get a replacement and test it. Others have reported problems with this, and I haven't seen anyone saying it works properly.
The Proto X (using the Hubsan X4 protocol) flips based on a stick dance, and from what I can tell the X4 does the same. You can disable/enable that with a switch on deviation. My Proto X model.ini provides a mode (also enabled by a switch setting) where going to full cyclic will make deviationTx do the stick dance for you in that direction. It should work fine for the Hubsan X4, but I don't have on to test it on. If you try it, please let me know. The same trick should work on the Proto X SLT if it binds.
It is for the Devo6, so you'll need to fix the switches to match your 7E.
- Tryptych
23 Mar 2015 23:00 - 23 Mar 2015 23:00 #30146
by Tryptych
Replied by Tryptych on topic Flipping a Hubsan X4 with Deviation
Hey mwm, sorry for the delay. I just installed my nRF24L01 this weekend and was able to bind my Syma X11 today. With that test done, I tried the Proto X SLT but had no luck. I am going to start a new thread about the SLT, please take a look here:
www.deviationtx.com/forum/6-general-disc...to-x-slt-bind-issues
Last edit: 23 Mar 2015 23:00 by Tryptych.
Time to create page: 0.197 seconds
- Flipping a Hubsan X4 with Deviation
