Protocol
14 Mar 2015 01:21 #29681 by RCdriver1
Protocol was created by RCdriver1
Yeah, I'm the dumbass newbie.
I just received my Devo 10, and was pretty happy that it worked with my PC adapter.
I will have to use the Spectrum firmware for the FBL controller that I will be getting(I think), so I followed all of the instructions, and seem to have that part taken care of.
Problem is, the PC no longer sees the transmitter.
I can also not find the firmware download on Walkera's site, to restore it.
Any help would be appreciated.
TIA,
Bryan
P.S.
The RC is short for Racecar from an old gamer tag. I'm clueless about this Radio Control stuff.
Kinda funny that back in the day after I shortened it to RC to add an clan tag, that all of the questions started, about what kind of RC stuff LOL.
14 Mar 2015 01:41 #29682 by RCdriver1
Replied by RCdriver1 on topic Protocol
Oh yeah,
I'm guessing it won't bind to the little Walkera CP I have coming either anymore.
I just thought this was going to add protocols, not replace them.
So any fixes to make it easier would be nice .
Thanks,
Bryan
14 Mar 2015 03:13 #29685 by RCdriver1
Well,
I found an v7 with an library v2, but no more PC adapter working.
I'm sure I'll have to run the deviation firmware for the FBL, and I'm sure the v7 Devo will work with the Walkera heli. Not too much hassle swapping, but would still like to run them all without having to swap back and forth. Especially if I want to keep my settings.
And I would still like to run the sims with this transmitter too.
Hoping y'all got some news.
I know it ain't been that long.
Just giving a heads up were I'm at.
Fix'n to throw some ducats down the proverbial hole of an Trex 600, and would hate to get another Tx just for the micro. That's supposed to be the whole purpose of the one transmitter. to get used to the one for all. I suffer enough on my FP RTF piece of junk toy.
Cheers,
Bryan
14 Mar 2015 04:58 #29688 by victzh
Replied by victzh on topic Protocol
What do you mean "PC no longer sees the transmitter"? Did you try turn the transmitter off, press EXT button (on the left) and while pressing it turn it on. On your PC using the DfuSe USB Upgrade tool and your TX connected to it, do you see anything in Available DFU devices in the top left corner of the utility? What version of DfuSe do you use?
14 Mar 2015 09:13 - 14 Mar 2015 09:17 #29693 by RCdriver1
My bad,
I was referring to the sim adapter I have.
It still has the USB capability.
So I'm able to change the firmware with no problem.
Out of the box, it worked with the adapter, and was seen by Windows, as an PPM.
It didn't see any of the switches, but the Gimbal channels worked great.
Smooooth as glass with Aerofly and neXt.
Just kinda bummed I lost that.
I'm sure I'll find the help I need in here to get this thing rolling though.
Thanks,
Bryan
P.S.
I used 1.7 for the first install of deviation, and 2.0 for the install of the version 7 firmware from Walkera(found an archive). The transmitter had version 8 out of the box, but my dumbass didn't back it up.
Last edit: 14 Mar 2015 09:17 by RCdriver1.
14 Mar 2015 09:47 - 14 Mar 2015 09:58 #29694 by linux-user
Replied by linux-user on topic Protocol
What are you trying?
Stock Walkera firmware or Deviation ?
With Deviation you can control Spektrum-receivers and Walkera and USB-capable Simulator and many more at the same time - You change between them, simply by selecting new Model in your TX.
Last edit: 14 Mar 2015 09:58 by linux-user.
14 Mar 2015 21:15 #29708 by RCdriver1
linux-user wrote: What are you trying?
That's what I'm hoping for.
The USB sim dongle may have just taken an @#$t.
I've already put the deviation back in, and am working with it.
I've already ordered an new dongle.
I'll report back in a few weeks, when I have everything in hand.
15 Mar 2015 06:18 #29722 by victzh
Yea, maybe you fried your USB dongle somehow. You need to select PPM as a protocol for your model for USB dongle to get the signal, check this as well.
15 Mar 2015 14:15 #29738 by RCdriver1
victzh wrote: Yea, maybe you fried your USB dongle somehow. You need to select PPM as a protocol for your model for USB dongle to get the signal, check this as well.
WHOOO HOOOO !!!!
Page 51, deviation manual.
Now to figure out channels and switches to be recognized by Windows.
The gimbals work great though, and are smooth as glass.
Just trying to get total control with the TX, and not have to reach for the keyboard.
Cheers
Bryan
Time to create page: 0.133 seconds
