cannot bind a hubsan X4
- vickyjim007
16 Mar 2015 17:30 #29764
by vickyjim007
cannot bind a hubsan X4 was created by vickyjim007
i use deviation 4.01 and build A7105 module, but i cannot bind a hubsan and flysky ,i uae a devo 10 white one, my control unit show on the model select only hubsan and flysky before the letter have * ,anybody can tell me how to solve the problem,
16 Mar 2015 22:00 #29770
Replied by mwm on topic cannot bind a hubsan X4
If you've got a '*' in front of the protocol name, then the Tx isn't seeing the A7105 module. Either it's not connected properly - in which case you're ignoring the missing module warning - or you haven't enabled it properly.
You need to edit tx.ini to enable the A7105, and set whether or not it has a PA.
- vickyjim007
- Deal57
18 Mar 2015 11:45 #29821
by Deal57
Replied by Deal57 on topic cannot bind a hubsan X4
You need to use a different editor. Most people seem to use Notepad++. Otherwise as you see the lines all run together.
Time to create page: 0.099 seconds
- cannot bind a hubsan X4
