cx10 problems
28 Mar 2015 21:14 #30386 by pmc
cx10 problems was created by pmc
hi
i have the cx 10 quad with the devo7e.
I have no problems binding but the controls dont react quickly .When i reduce the throtle it takes a few seconds before the quad reacts.Does anybody no how to solve this.i have tried many differant ini s but they al have the same problem.The remote that came with the quad works fine.
29 Mar 2015 14:01 - 29 Mar 2015 14:02 #30402 by Durete
Replied by Durete on topic cx10 problems
I never found any problem flying my CX-10 with my Devo. Your issue is very strange. Are you completely sure your nRF24L01 module is ok? So, it's working perfect with another model using the same module?
BTW, what Deviation version do you have installed?
Last edit: 29 Mar 2015 14:02 by Durete.
29 Mar 2015 15:30 #30404 by pmc
Replied by pmc on topic cx10 problems
hi
i have no problems with other models using nrf module.the version i now use is v4.0.1-c9b08a7.i have tried loading other versions but these have the same problem.
30 Mar 2015 21:48 #30491 by victzh
Replied by victzh on topic cx10 problems
Durete, are we talking about controlling Cheerson CX-10 with Devo and nRF24L01+ module? What protocol code do you use? I was not so lucky and there is a thread discussing it with very little luck: www.deviationtx.com/forum/protocol-devel...nt/3368-jd-395-cx-10
How did you manage to do this?
30 Mar 2015 22:03 - 30 Mar 2015 22:03 #30493 by Durete
victzh wrote: Durete, are we talking about controlling Cheerson CX-10 with Devo and nRF24L01+ module? What protocol code do you use? I was not so lucky and there is a thread discussing it with very little luck: www.deviationtx.com/forum/protocol-devel...nt/3368-jd-395-cx-10
Hi Victzh.
There are 3 CX-10 versions. The first original version (Red PCB version) uses YD717/Skywalker protocol using nRF module.
The thread you linked me, is about the second "Green PCB version", with XN297 module.
After these version, the sellers start to sell a new "Blue PCB version" with XN297 module but different protocol than "Green PCB version".
It's a shame, because the original version could be controlled with Devo TX but the better flyer it's probably the Green PCB version.
Last edit: 30 Mar 2015 22:03 by Durete.
30 Mar 2015 22:25 #30496 by pmc
I have the New blue version.
I have the devo 7e versie 4.0.1
It har noen options for the protocol, just yd717.It binds without any problems. I just need a good ini to try. If you have One please post it.
30 Mar 2015 22:27 #30497 by pmc
I have the devo 7e with nrf_+ module. Binds without problems, just need a good ini to try.
30 Mar 2015 22:29 #30498 by Durete
pmc wrote: I have the New blue version.
So you are trying to fly a Blue PCB CX-10 with your Devo? :huh:
Sorry, It's not possible :( . The only version works with Devo TX it's the Original First Red version, using YD717/Sky Walker protocol.
30 Mar 2015 22:37 #30499 by pmc
I will Let you know if i get it working. Binds great, just recieved an ini. Try it in the morning.
01 Apr 2015 17:08 #30628 by pmc
hi
you were right it was difficult so i went to a hardware sollution.
please look at my hardware sollution in general discussions.
28 May 2015 17:03 - 28 May 2015 17:04 #33136 by stringrazor
Replied by stringrazor on topic cx10 problems
just a public service msg for anyone late to the CX10 party (like me):
see www.deviationtx.com/forum/protocol-devel...-395-cx-10?start=200 for goebish's test build that works for green & blue board CX10's (w/NRF... mod).
Last edit: 28 May 2015 17:04 by stringrazor.
Time to create page: 0.587 seconds
