Trims buttons as transmitter channels
12 Apr 2015 09:02 #31082 by luenma
Hi, I am trying to use the two upper Right and Left Trims as separate transmitter channels, but do not know the way to do it. With the official firmware you can chose those two Trims as transmitters channels and I suppose it is also possible to do it with Deviation, but I do not find the way to do it. I appreciate any help about that.
Thanks and regards.
12 Apr 2015 11:52 #31098 by luenma
Replied by luenma on topic Trims buttons as transmitter channels
Solved. I have just seen it is possible to define one virtual channel with the value of zero and then add the trims. So, at the end by using that virtual channel in one transmitter channel it is possible to use those trims as transmitter channels. Perfect.
Time to create page: 0.091 seconds
