What is the minimum voltage for Devo 8S?
14 Apr 2015 14:57 #31172 by luenma
Hi, I am using in my Devo 8S 4 x 1.5V AA alkaline batteries. I am not sure about the value I should put for the battery alarm in the transmitter config menu. What is the minimum recommended voltage for Devo 8S transmitter?
Thanks and regards
14 Apr 2015 15:20 #31176 by PhracturedBlue
Replied by PhracturedBlue on topic What is the minimum voltage for Devo 8S?
the minimum voltage is actually dependent on battery chemistry. For operation, I recommend >4.0V. Too much below that and the flash memory will not write reliably. I think that is a good number for Alkaline batteries since their voltage curve is pretty smooth down past 1V. For NiMH I'd probably set it at 3.9 because of their lower initial voltage.
15 Apr 2015 09:16 #31195 by luenma
Replied by luenma on topic What is the minimum voltage for Devo 8S?
Thank you very much, I am going to follow your recommendation.
Time to create page: 0.108 seconds
