DEVO10 flashing deviation-devo12-v4.0.1
- samlawyy
17 Apr 2015 03:20 #31272
by samlawyy
DEVO10 flashing deviation-devo12-v4.0.1 was created by samlawyy
I was try to flash the deviation-devo12-v4.0.1 to my DEVO10, but after finish upgrade I turn off my devo10 and try to get into the USB mode...but it's not work.. I can't turn it on again..
Am I do a stupid work?.. can I return it to deviation-devo10?
17 Apr 2015 03:36 - 17 Apr 2015 03:40 #31273
Replied by PhracturedBlue on topic DEVO10 flashing deviation-devo12-v4.0.1
with the devo10 there is no indicaton of 'on' (unlike the devo8/12). It is likely in a boot loop hung in a hard-fault. tun off the Tx, unplug the battery, wait 10seconds, plug in the battery, power up while holding EXT. Putting the wrong ROM on the TX will not damage the Tx in any case I've seen.
Last edit: 17 Apr 2015 03:40 by PhracturedBlue.
- Cereal_Killer
17 Apr 2015 03:37 - 17 Apr 2015 03:39 #31274
by Cereal_Killer
Replied by Cereal_Killer on topic DEVO10 flashing deviation-devo12-v4.0.1
Edit: I misread your first post, I didn't see you tried the wrong file. Follow PB's instructions and start new, it'll be fine.
When you try to turn it on what exactly happens?
Does the computer recognize it as a USB drive? It should, if it took the flash correctly it won't boot till it's formatted and the new file system loaded.
Try this:
* Tx off, plug in USB between it and computer.
* Hold ENT, switch on TX
* computer should recognize it as USB drive
* Format it. Use default settings
* copy needed files/directories from the .zip into the root of the USB drive
* "Eject" USB drive
* Switch Tx off
* Switch back on with no buttons pressed (cable may be in place or removed for this, no difference). It should boot.
Try this:
* "Eject" USB drive
* Switch Tx off
Last edit: 17 Apr 2015 03:39 by Cereal_Killer.
- samlawyy
17 Apr 2015 16:23 - 17 Apr 2015 16:24 #31305
by samlawyy
Replied by samlawyy on topic DEVO10 flashing deviation-devo12-v4.0.1
I have follow your guide to flash it back to deviation10, unplug the battery, wait 10seconds, plug in the battery, power up while holding EXT.
Thank you very much !
My Devo10 is back!
My Devo10 is back!
Last edit: 17 Apr 2015 16:24 by samlawyy.
Time to create page: 0.208 seconds
- DEVO10 flashing deviation-devo12-v4.0.1
