Devo 10 telemetry help needed
17 Apr 2015 04:07 #31275 by anatoly
Devo 10 telemetry help needed was created by anatoly
My radio lost model settings I had to do it all from the scratch. Telemetry was working but now it says "telemetry turned off" when you try to set it.
My telemetry module is connecting to the radio, has a solid light, but Devo 10 in Deviation says that telemetry is turned off when I try to set it up by accessing telemetry menu.
How do I turn it on in Deviation?
How do you save the model, because when I try to load the model -- it has unsaved next to model name?
Thank you for your assistance.
17 Apr 2015 04:31 - 17 Apr 2015 04:31 #31277 by vlad_vy
Replied by vlad_vy on topic Devo 10 telemetry help needed
You can enable telemetry in protocol options. Press protocol name and enable telemetry (ON). Model settings will saved at shutdown or when you change model.
Last edit: 17 Apr 2015 04:31 by vlad_vy.
Time to create page: 0.079 seconds
