Servo 180º
- luenma
29 Apr 2015 08:17 #31793
by luenma
Servo 180º was created by luenma
I am wondering if it is possible with Deviation to rotate the servos 180º instead of 90º without any external servo travel expander or hardware modification. I understand it is only to decrease the pulse wide below 1 ms and increase it above 2 ms. Is that one hardware limitation in the receivers or is it possible to solve it by software?
Thanks and regards.
Thanks and regards.
- linux-user
29 Apr 2015 08:25 #31795
by linux-user
Replied by linux-user on topic Servo 180º
AFAIK the pulse wide is under sole control of the RX.
- luenma
29 Apr 2015 22:50 #31822
by luenma
Replied by luenma on topic Servo 180º
Thanks for your answer. Ok, understood. Then the cheapest solution is to add two resistors into the servo.
- kungpow
29 Apr 2015 23:40 - 29 Apr 2015 23:40 #31824
by kungpow
Replied by kungpow on topic Servo 180º
If you click on the channel you can raise the maximum travel percentage and get some more travel that way.
Last edit: 29 Apr 2015 23:40 by kungpow.
Time to create page: 0.104 seconds
