Ch6 and Ch7 problem
02 May 2015 12:48 - 02 May 2015 15:03 #31938 by vlad_vy
Ch6 and Ch7 problem was created by vlad_vy
It seems I have channels 6 and 7 mixed for Devo protocol and RX1202.
Ch6 - Mix=Simple, Src=ELE, all other is default
Ch7 - Mix=Simple, Src=AIL, all other is default
Both channels work simultaneously if I move elevator to the UP or aileron to the LEFT, but not work if I move elevator to the DOWN or aileron to the RIGHT. At channel monitor both channels work as expected. I don't understand what is happened. All other channels with the same setup work normally.
If for Ch7 Mix=None, Ch6 work only if I move elevator UP.
Can anybody check it ???
Last edit: 02 May 2015 15:03 by vlad_vy.
02 May 2015 14:00 #31949 by vlad_vy
Replied by vlad_vy on topic Ch6 and Ch7 problem
Probably it can be defective RX1202.
02 May 2015 14:34 #31954 by vlad_vy
Yes, Ch6 and Ch7 output pins are shorted, but I don't see at circuit board any thing that shorted these pins.
02 May 2015 14:50 #31955 by vlad_vy
Solved. It was hair thin solder bridge.
Time to create page: 0.483 seconds
