Add flybarless system to my devo Rx
07 May 2015 17:48 #32215 by saad khan
Add flybarless system to my devo Rx was created by saad khan
Hello, Kindly help me regarding, that is I can connect any flybarless system to my rx801 receiver If yes, then tell me which one and how.
Kindly help me regarding this issue.
07 May 2015 18:51 #32218 by Thomas.Heiss
Replied by Thomas.Heiss on topic Add flybarless system to my devo Rx
FBL for what? Heli?
You can choose any FBL system as long as you connect each servo CH cable to your Devo RX.
The more modern FBL systems support S-Bus, SUMD, SRXL & and stuff.
For example Spirit System, ZYX-s, etc.
What FBL system you choose will depend on the features you would like to get.
Greetings
Thomas
07 May 2015 19:04 - 07 May 2015 19:06 #32219 by linux-user
Replied by linux-user on topic Add flybarless system to my devo Rx
The Devo-RX801 is a standard PWM receiver.
So any FBL that can cooperate with a "standard" receiver should work.
On some FBL the number of channels is limited due to lack of enough PWM ports.
So you may not be able to use every feature of the FBL.
Last edit: 07 May 2015 19:06 by linux-user.
08 May 2015 08:24 #32238 by saad khan
Replied by saad khan on topic Add flybarless system to my devo Rx
Thanks. So it means I can use Tarot ZYX-S2 3-Axis Gyro Flybarless System. But tell me the procedure that how to connect it to my receiver.
08 May 2015 08:26 #32239 by saad khan
Also is I connect it to my rx2702. I am not satisfied from its gyro stabilization.
14 May 2015 21:09 - 14 May 2015 21:09 #32585 by saad khan
I want ti use K- Bar. Should It will work with my walkera rx801
Last edit: 14 May 2015 21:09 by saad khan.
17 May 2015 20:51 #32707 by Thomas.Heiss
You may want to download the vendor documentation and see how the servo cables connect to a standard receiver.
ZYX also has a PC software which graphically shows you the interconnections between FBL and standard RX.
So does probably V-Stabi software.
Ail, Elev, Aux1 (ZYX uses e.g special 1->3 plug servo cable), Gyro=Gear or AUX2, Rudd,
THR to ESC
17 Jun 2015 10:46 #34212 by Thomas.Heiss
Spirit System FBL supports now "Spektrum SRXL" (9 channel receiver) as of firmware version 1.2.0.
As does BeastX Plus/Pro support "Spektrum SRXL".
Time to create page: 0.485 seconds
