Add flybarless system to my devo Rx
- saad khan
07 May 2015 17:48 #32215
by saad khan
Add flybarless system to my devo Rx was created by saad khan
Hello, Kindly help me regarding, that is I can connect any flybarless system to my rx801 receiver If yes, then tell me which one and how.
Kindly help me regarding this issue.
- Thomas.Heiss
07 May 2015 18:51 #32218
by Thomas.Heiss
Replied by Thomas.Heiss on topic Add flybarless system to my devo Rx
FBL for what? Heli?
You can choose any FBL system as long as you connect each servo CH cable to your Devo RX.
The more modern FBL systems support S-Bus, SUMD, SRXL & and stuff.
For example Spirit System, ZYX-s, etc.
What FBL system you choose will depend on the features you would like to get.
Greetings
Thomas
Greetings
Thomas
- linux-user
07 May 2015 19:04 - 07 May 2015 19:06 #32219
by linux-user
Replied by linux-user on topic Add flybarless system to my devo Rx
The Devo-RX801 is a standard PWM receiver.
So any FBL that can cooperate with a "standard" receiver should work.
On some FBL the number of channels is limited due to lack of enough PWM ports.
So you may not be able to use every feature of the FBL.
Last edit: 07 May 2015 19:06 by linux-user.
- saad khan
08 May 2015 08:24 #32238
by saad khan
Replied by saad khan on topic Add flybarless system to my devo Rx
Thanks. So it means I can use Tarot ZYX-S2 3-Axis Gyro Flybarless System. But tell me the procedure that how to connect it to my receiver.
- saad khan
08 May 2015 08:26 #32239
by saad khan
Also is I connect it to my rx2702. I am not satisfied from its gyro stabilization.
- saad khan
14 May 2015 21:09 - 14 May 2015 21:09 #32585
by saad khan
I want ti use K- Bar. Should It will work with my walkera rx801
Last edit: 14 May 2015 21:09 by saad khan.
- Thomas.Heiss
17 May 2015 20:51 #32707
by Thomas.Heiss
You may want to download the vendor documentation and see how the servo cables connect to a standard receiver.
ZYX also has a PC software which graphically shows you the interconnections between FBL and standard RX.
So does probably V-Stabi software.
Ail, Elev, Aux1 (ZYX uses e.g special 1->3 plug servo cable), Gyro=Gear or AUX2, Rudd,
THR to ESC
THR to ESC
- Thomas.Heiss
17 Jun 2015 10:46 #34212
by Thomas.Heiss
Spirit System FBL supports now "Spektrum SRXL" (9 channel receiver) as of firmware version 1.2.0.
As does BeastX Plus/Pro support "Spektrum SRXL".
Time to create page: 0.483 seconds
- Add flybarless system to my devo Rx
