CC2500/FrSky signal problems
18 May 2015 19:16 #32750
CC2500/FrSky signal problems was created by mwm
I swapped my OrangeRx 610 for a D4R-II, and the range went from fine to hundreds of feet to about 40 feet. This is pretty much unusable.
Since the D4R-II has RSSI now, I get a reading for signal strength - but there's no documentation as to what it means. With the Tx & Rx both sitting on my desktop, about a foot apart, it reads 50. I suspect that's not good, but would like confirmation on that.
I get the same behavior on the desktop from several D4R-II's. This makes me suspect that the problem is the CC2500, though it may be the connection. Anything I should look at there? In particular, I'm using relatively long signal lines, so maybe there's a timing issue there and I should shorten them?
Any other suggestions for things I might try before ordering another CC2500?
- RedSleds
18 May 2015 20:51 #32753
by RedSleds
Replied by RedSleds on topic CC2500/FrSky signal problems
has_pa, line commented out?
18 May 2015 20:55 #32754
Replied by mwm on topic CC2500/FrSky signal problems
No, it's not commented out. The module has a PA.
- RedSleds
18 May 2015 21:00 #32755
by RedSleds
...and is it: = 1 ?
18 May 2015 21:08 #32756
Yes.
01 Jun 2015 15:48 #33325
The replacement CC2500 showed up, and doesn't work - just shows up as missing when I boot deviation.
The wiring is right - pretty much just moved the wires from the old one. Connections all beep as fine. I verified that I'm getting 3.2+ volts between the vcc & ground lines. So if it's not the module, it's my job soldering on the pins.
Now that I have a logic analyzer I trust a little, I'm trying to figure out if I can debug this further before giving up and ordering another module.
Is there some test I can make to double check that I have things connected properly? Given that the module isn't responding, are there signals I can watch for on some pins that should still show something on power on? If they show the right values, is there some way to distinguish between an rf module that's not responding and a pin that's connected to the Devo but not the rf module?
- anansi22
15 Nov 2015 06:36 #40070
by anansi22
Replied by anansi22 on topic CC2500/FrSky signal problems
Did you resolve this issue? If so, what was your solution
15 Nov 2015 15:39 #40080
Yes. The wiring was wrong - I was misreading the docs (which have since been clarified), and failed to add the jumpers it needed to the module. Adding those solved things.
Time to create page: 0.038 seconds
- CC2500/FrSky signal problems
