Calibrating CX-10
14 Jun 2015 03:34 #34041 by Michael_Hahnel
Calibrating CX-10 was created by Michael_Hahnel
Hi. I have problem with my new Devo 7e & the red PCB CX-10.
the Yaw is not straight and the Quade is turning in normal setting. It there a way I can calibrate the CX-10 or Devo 7e ?
Thank for info to a newby to this :)
14 Jun 2015 06:25 #34047 by racemaniac
Replied by racemaniac on topic Calibrating CX-10
you can (and should) calibrate your devo 7e after uploading the deviation firmware
In the main menu go to:
Main menu -> transmitter menu -> transmitter config -> generic settings: sticks : calibrate
