How to assign channel 5 to the gear switch?
17 Jun 2015 11:53 - 17 Jun 2015 11:55 #34215 by ShawnecJP
I was wondering what's the easiest way to assign channel 5 to the gear switch on the devo 10?
I am using the Naze32 for my quad and I want to flip between arco and auto level...
I just used one of the existing models files and I just want to alter that.
I'm a newbie with both the naze32 and tx so I'm not 100% sure.
Thanks for any help :)
Last edit: 17 Jun 2015 11:55 by ShawnecJP.
17 Jun 2015 12:22 #34217 by FDR
Set the mixer type of Ch5 to simple mixer, and select the GEAR1 as the source...
17 Jun 2015 12:52 #34221 by ShawnecJP
Replied by ShawnecJP on topic How to assign channel 5 to the gear switch?
Do I have to be in advanced GUI to access that?
I'm just not exactly sure where to access that.
When I said newbie I really meant newbie.... Sorry :oops:
17 Jun 2015 13:00 #34223 by ShawnecJP
I just checked in the deviation manual and answered my own question
Thank u!
17 Jun 2015 13:29 - 17 Jun 2015 13:30 #34224 by ShawnecJP
I just went and changed to advanced GUI, went back to the model menu, went to mixers and scroll down to channel 5. I wasn't given the option based on what you said....
This was my view
Last edit: 17 Jun 2015 13:30 by ShawnecJP.
17 Jun 2015 17:01 #34228 by FDR
You were on the right track at your image 2.
Navigate to the <None> field, and change it to <Simple>.
Then additional filds will appear, four example the source field, which is probably named as "Src".
Change it's value to GEAR1, save it with the upper button, and you are done.
17 Jun 2015 21:52 #34240 by ShawnecJP
That did the trick!!
Thank you so much for this advice!!
17 Jun 2015 22:47 #34242 by ShawnecJP
I find that the deviation manual is very tricky, especially to somebody new like me who doesn't have a lot of technical knowledge on programming .
Is there a manual out there that is written in more plain speech? I tried to search for this answer online before I came here and asked anyone. There could very well be such a manual or a place where everything is centrally located but I couldn't find it.
Your explanation on how to do what I did was very easy to understand Haha.
Thanks again for briefly holding my hand through this step.
18 Jun 2015 02:17 #34249 by mwm
I wrote a tutorial on writing a model config . It would have covered this issue. Walks you through configuring a model from scratch, in great detail. Might be what you're looking for..
18 Jun 2015 02:52 #34251 by ShawnecJP
Sweet! Thanks!
I would be very interested. I hate not being able to use the things I own properly.
Time to create page: 0.091 seconds
