Failsafe devo10/rx1002 w/naze32
25 Jun 2015 05:33 - 25 Jun 2015 05:33 #34615 by ShawnecJP
Failsafe devo10/rx1002 w/naze32 was created by ShawnecJP
Hi
I have my failsafe set up. I turn off the transmitter and everything shuts down.
That part is good :)
What I'm wondering is, is there anyway for the TX to reestablish a connection with the RX at the time when I connection is established again?
When I turn my transmitter back on again it won't connect.
I have to unplug the battery from the quad and replug it back in again for everything to reinitiate properly.
I don't know if this has anything to do with it or not ( i'm thinking it does)..... Every time before I fly when I turn on my transmitter it takes 10 seconds for my devo 10 to bind with my quad every single time....
The picture below is what I see I might be screened every time I connect.
Last edit: 25 Jun 2015 05:33 by ShawnecJP.
25 Jun 2015 05:42 #34616 by FDR
Replied by FDR on topic Failsafe devo10/rx1002 w/naze32
Do you use fixed ID? It can help...
25 Jun 2015 07:20 #34622 by ShawnecJP
Replied by ShawnecJP on topic Failsafe devo10/rx1002 w/naze32
FDR wrote: Do you use fixed ID? It can help...
I do not.
When I was first binding the quad to my radio ( for the very first time... A couple of weeks ago ) I was reading that I couldn't use a fixed ID. I thought that that had meant from here on in.
Was that just for the initial binding????
25 Jun 2015 09:53 #34627 by Thomas.Heiss
Replied by Thomas.Heiss on topic Failsafe devo10/rx1002 w/naze32
How fast is the re-connect with FixedID?
Spektrum had introduced on some newer DSM2 receivers quick connect.
On Spektrum DSMx the re-connect once TX-signal is lost is quite fast too.
25 Jun 2015 11:29 #34643 by FDR
I do not.
Yes, for the first bind you must use the autobind, then set the fixed ID, and send it to the rx.
After that you can turn them on in any order, and it usually reconnects after a tx reboot too...
25 Jun 2015 11:35 #34645 by ShawnecJP
FDR wrote:
I do not.
Bahaha
Thanks man! I feel pretty silly now...
Time to create page: 0.172 seconds
