Devo F12E Deviation Firmware ?
12 Jul 2015 22:05 #35386 by Gunawan
Devo F12E Deviation Firmware ? was created by Gunawan
Hi, i am new member here. i have Devo F12E Radio. is there any deviation firmware for Devo F12E ? Where can i find it ? i Just found Devo12. Thanks.
13 Jul 2015 00:07 #35389 by dc59
Replied by dc59 on topic Devo F12E Deviation Firmware ?
You can find firmware at nightly build here
But before you install it , plaese read this thread :
www.deviationtx.com/forum/3-feedback-que...-deviation-devo-f12e
26 Jul 2015 14:13 #36044 by Gunawan
Replied by Gunawan on topic Devo F12E Deviation Firmware ?
thanks dc59. I have installed the firmware but my aux 6 and aux 7 seems abnormal. when i move the slider the value from -100 suddenly becomes 100. can not have 0 value even i have centered the slider. anybody have the same problems ?
26 Jul 2015 15:10 #36050 by dc59
Gunawan wrote: thanks dc59. I have installed the firmware but my aux 6 and aux 7 seems abnormal. when i move the slider the value from -100 suddenly becomes 100. can not have 0 value even i have centered the slider. anybody have the same problems ?
Did you calibrate all sticks/knobs/switches after installing firmware?
Transmitter menu -> Transmitter config -> Calibrate
26 Jul 2015 20:39 #36077 by Gunawan
i did calibrate all sticks knobs,sliders. only aux 6 and 7 do not work normally.
26 Jul 2015 23:50 #36100 by PhracturedBlue
Replied by PhracturedBlue on topic Devo F12E Deviation Firmware ?
Please file a ticket. I won't be able to look into it for a few weeks.
27 Jul 2015 00:03 #36102 by dc59
Hi PB,
I also meet a problem with my TX, my FS seems to be crashed suddenly, now I can't save anything,
and it's always like the picture below when I reboot my TX.
Every setting is gone.
I will try to reinstall FW again,if I get any clue, I will report it.
I will file a ticket for it, thank you very much.
27 Jul 2015 10:46 #36135 by PhracturedBlue
filesystem corruption is very hard to debug. I would need to see an image of the corrupted file system (i.e. download the flash to the pc and send it to me). That can be done without too much effort, but it is likely you've already reformatted and lost it now.
27 Jul 2015 10:59 #36138 by dc59
PhracturedBlue wrote: filesystem corruption is very hard to debug. I would need to see an image of the corrupted file system (i.e. download the flash to the pc and send it to me). That can be done without too much effort, but it is likely you've already reformatted and lost it now.
Hi PB,
How to download flash to PC?
Is there a software to do it?
Thanks.
27 Jul 2015 15:29 #36156 by mwm
Replied by mwm on topic Devo F12E Deviation Firmware ?
If you're using Unix (including a Mac) or a Unix-like system, you can use "dd" to make a copy of the file system. This will also work in a VirtualBox VM running such. If all you've got is Windows and none of that stuff installed, there's probably a tool available that will do this for you, but I don't know what it would be.
Let us know if you've got something running Unix available somewhere, and I can provide the instructions for making a copy.
28 Jul 2015 00:03 - 28 Jul 2015 00:04 #36195 by dc59
mwm wrote: If you're using Unix (including a Mac) or a Unix-like system, you can use "dd" to make a copy of the file system. This will also work in a VirtualBox VM running such. If all you've got is Windows and none of that stuff installed, there's probably a tool available that will do this for you, but I don't know what it would be.
Thanks mwm for those info.
But it seems too difficult to me, I never used Unix ..... , I use only Windows OS.
I re-installed my F12E FW with 7/26 nightly build, it seems OK now , but i'll try to re-produce that crash again
and report it.
By the way, do you know how to File Manager on Deviation Uploader ?
Sometime I can get the list , sometimes not , what's correct step to get it?
Is there a manual for Deviation Uploader?
Thanks.
Last edit: 28 Jul 2015 00:04 by dc59.
Time to create page: 1.096 seconds
