DEVO7E PPM-> USB Help
- Mathew
23 Jul 2015 15:14 #35858
by Mathew
DEVO7E PPM-> USB Help was created by Mathew
Hi guy.
i want to use my DEVO7e as an Gamepad to use it with Heli-X. I could conect the Devo to my PC but it only reconized channel 1-4. I created an simple config with 6 Channels.
Channel 5 should be The Flymode Switch and channel 6 should be the Pitch Channel. The Channel Monitor show the right values (channel 5 off=-100 on=100) but like i said above Channel 5 and 6 willbe ignored by my pc.
Maybe somebody could help me. I try different setting without succes.
Maybe its possible to use the Hold and Fnid Switches an an simple button?! Try to use the virtual buttons but without succes
- goophoba
03 Aug 2015 23:57 - 03 Aug 2015 23:57 #36518
by goophoba
Replied by goophoba on topic DEVO7E PPM-> USB Help
RealFlight wouldn't see my switches until I messed with the mixer. Here's my ini for PPM to PC.
Last edit: 03 Aug 2015 23:57 by goophoba.
- Mathew
08 Aug 2015 08:59 #36677
by Mathew
Replied by Mathew on topic DEVO7E PPM-> USB Help
Thank you. I tried it but i got the same results as before. I gues its a Problem with my USc PPM Adapter, But thanks anyway,
- goophoba
08 Aug 2015 19:48 - 08 Aug 2015 19:53 #36685
by goophoba
I don't know if it'll help but you can try virtual switches like you mentioned. It was unclear if you couldn't get virtual switches going in the 7E, PC, or both.
I've updated the ini to use the throttle trim as channel 7 and 8 on my 7E. I'll upload it when I get back home.
Last edit: 08 Aug 2015 19:53 by goophoba.
- goophoba
- Mathew
09 Aug 2015 09:54 #36706
by Mathew
Thank you i try it but without succes. Windows is showing that the ppm connect got 3 Buttons (German: Schaltflächen) but non of them is working when i trigger any button on the Devo. The Axis are working well.
When i use the USB Cable everything is working fine but it is very unconfortable to hold the Devo.
So my suggestion is that the ppm-Usb adapter isnt working probertly
Time to create page: 1.111 seconds
- DEVO7E PPM-> USB Help
