simulator for Deviation
24 Jul 2015 08:45 #35891 by masav71
simulator for Deviation was created by masav71
Hi!
What is good simulator software for windows/Deviation ?
do i need something else that the usb-cable?
-Matti-
24 Jul 2015 10:06 #35897 by Zaphod
Replied by Zaphod on topic simulator for Deviation
I've used Phoenix and Heli-x with my Deviation Devo 10.
Of the 2 I'd recommend Heli-x with a USB cable.
03 Aug 2015 16:36 #36504 by masav71
Replied by masav71 on topic simulator for Deviation
so is the usb cable that came whit heli ok?
-Matti-
15 Aug 2015 17:07 #36919 by masav71
Hi!
i downloaded heli-x to win 10 laptop 64bit.
installation ok. software seems working ok, but " no controller found"---i have devo 10 with original usb cable.
Deviation updater does not either regognice my controller anymore , is is because of updatin win 7 to win10?
in whitch mode i should start tx when i want to use simulator?
any suggestion??
-Matti-
17 Aug 2015 09:58 #36970 by frogamic
Replied by frogamic on topic simulator for Deviation
You need to add a model for it with the USBHID protocol.
17 Aug 2015 19:34 #36998 by masav71
Hi!
where can i find it? from forum?
copter is walkera v120d02s
tx is devo 10
is heli-x win 10 compatible?
should i tell win that devo is gamecontroller?
-Matti-
17 Aug 2015 20:00 #37001 by mickkn
Replied by mickkn on topic simulator for Deviation
If you like FPVracing, go for FPV Freerider. Works with the usbhid directly connected. At least on Mac OSX. Haven't tested on windows, buy why should it not :)
20 Aug 2015 16:45 #37074 by greenfly
Replied by greenfly on topic simulator for Deviation
masav71 wrote: Hi!
-Matti-
You already have USBHID.
You have to create a new model and select USBHID as the protocol. (It's at the end of the list)
20 Aug 2015 17:58 #37080 by masav71
okay, i`ll try.
thanks
-matti-
26 Aug 2015 04:28 #37212 by masav71
working perfectly!
thanks for tips !
-matti-
Time to create page: 0.186 seconds
