Replacement Tx
- DoubleQuad
26 Jul 2015 11:08 #36026
by DoubleQuad
Replacement Tx was created by DoubleQuad
OK, so I bought a Devo 7e and whilst performing the range mod, I inadvertently removed not only the resistor I was trying to bridge but another one close to it.
The Tx still works, but it would seem that it is now destined to forever output only 10 mW, which renders it useless.
So that puts me in need of a new Tx, and as much as I liked the 7e (in the brief time I have owned it) I am wary of attempting the range mod again.
I am now thinking of a Devo 10 (along with Turning 9XR Pro / OrangeRx T-Six and FlySky FS-T6). For someone who is a park flyer with thoughts of flying FPV, is there ANY downside to a Devo 10?
To add to the mix, is there any possibility that my 7e may be brought out of its 10 mW damnation?
- Arakon
26 Jul 2015 12:42 #36034
by Arakon
Replied by Arakon on topic Replacement Tx
You could buy the 8S upgrade module and just disable the internal module. You'll get full range.
- Zaphod
26 Jul 2015 13:10 #36036
by Zaphod
Replied by Zaphod on topic Replacement Tx
The only issue I've had with my Devo 10 is the hinges on the battery cover.
I'd do the 8s upgrade on your 7e.
- DoubleQuad
26 Jul 2015 18:51 #36073
by DoubleQuad
Replied by DoubleQuad on topic Replacement Tx
8s upgrade you say?
I shall investigate!
Thanks guys
Thanks guys
- DoubleQuad
26 Jul 2015 20:30 - 26 Jul 2015 20:57 #36075
by DoubleQuad
I've found the mod and ordered the parts...
Woohoo!!
Woohoo!!
Last edit: 26 Jul 2015 20:57 by DoubleQuad.
- DoubleQuad
27 Jul 2015 18:37 #36178
by DoubleQuad
Is it absolutely necessary to remove the old module when performing this mod?
Thanks.
Thanks.
- raduque
28 Jul 2015 00:48 #36201
by raduque
Replied by raduque on topic Replacement Tx
I don't know if it's necessary, but I removed it.
- DoubleQuad
28 Jul 2015 02:12 #36215
by DoubleQuad
Cool:)
I'll check it out when I pull my Tx apart... Again... For the last time
Thanks for your help!
- Arakon
28 Jul 2015 04:29 #36222
by Arakon
At the very least, you'd have to stop the module from trying to send data to the transmitter, otherwise they'll interfere.
Time to create page: 0.785 seconds
- Replacement Tx
