fixed id witch several transmitters?
- TomPeer
28 Jul 2015 13:56 #36245
by TomPeer
fixed id witch several transmitters? was created by TomPeer
I have 4 devo transmitters, i can bind them all to a moddel (not at once offcourse) if i do not set a fixed ID.
I would like to use a fixed ID, but then only the transmitter with witch i set that ID will bind. I can not bind the other transmitters anymore with that model.
Is there a possibillity to use fixed ID and use all the transmitters. (again, not at once). I vagely remember something about giving each transmitter the same number, but i can not find it again.
Thanks for any help.
Tom
Tom
28 Jul 2015 15:06 - 28 Jul 2015 15:12 #36247
Replied by vlad_vy on topic fixed id witch several transmitters?
You need modify file 'hardware.ini' for each transmitter with the same 'txid' and rebind once with any transmitter.
www.deviationtx.com/forum/3-feedback-que...202rx?start=20#20460
Last edit: 28 Jul 2015 15:12 by vlad_vy.
- TomPeer
28 Jul 2015 15:17 #36248
by TomPeer
Replied by TomPeer on topic fixed id witch several transmitters?
Great, Thank you very much.
Time to create page: 0.411 seconds
- fixed id witch several transmitters?
