ini files
10 Aug 2015 22:56 #36749 by randal flagg
ini files was created by randal flagg
hi guys I'm new to deviation I have a devo 6 and I'm just wondering how to get ini files to read when I load them also looking for the rite ini files for v120do2s and v977 thanks
10 Aug 2015 23:01 #36751 by randal flagg
Replied by randal flagg on topic ini files
do I just drag and drop ini files to the model file or maby I have the wrong ini files
10 Aug 2015 23:10 #36752 by TomPeer
Replied by TomPeer on topic ini files
yes, you can copy ini files from your computer to the transmitter as usb drive.
Just make sure the files are named : model1.ini, model2.ini, etc.
Do not give the ini files other names, than the transmitter will not see them.
10 Aug 2015 23:40 #36753 by randal flagg
there are 30 models from 1 to 30 shuld I replace one and change the file name thanks by the way I have a lot of learning to do
11 Aug 2015 00:31 #36756 by TomPeer
Yes. You can pick a empty file, and replace that with an ini file you want to use. For example. You have an ini file named v120.ini you want to use. Go to you model file in the tx. Choose a number you want to use, for example model3.ini. rename v120.ini to model3.ini and replace the file on the transmitter.
11 Aug 2015 00:53 #36757 by randal flagg
thanks mate
11 Aug 2015 00:56 - 11 Aug 2015 00:59 #36758 by TomPeer
Here are my ini files. They are for a Devo 10. I do not know if the switches on a devo 6 are the same.
Model 8 is for WLToys V977
gear is 3ax gyro / 6 ax gyro
Fmod is 3d mode
File Attachment:
File Name: model8.ini
File Size:2 KB
Model 12 is for Walkera V120D02S
Fmode = 3d mode
File Attachment:
File Name: model12.ini
File Size:4 KB
I use Rud DR for throttle hold. I don't think the 6 has that switch, so you might want to change that.
If this does not work than please tell me what switches you have and which you want to use for what, then i can try make a ini for you.
EDIT. here it is 3 o'clock in the morning, so that will be tomorrow.
Last edit: 11 Aug 2015 00:59 by TomPeer.
11 Aug 2015 01:14 #36760 by randal flagg
I cant download these files they just link me to a website
11 Aug 2015 01:16 #36761 by TomPeer
use the right mouse button, than save as..
should work.
11 Aug 2015 01:28 - 11 Aug 2015 01:33 #36762 by TomPeer
Otherwise try this link for the V977
www.deviationtx.com/forum/protocol-devel...-v977?start=40#23217
And here for the V120:
www.deviationtx.com/forum/model-configs/...inner-settings#19451
PS for the V977 you have to install an NRF24L01 module.
Last edit: 11 Aug 2015 01:33 by TomPeer.
11 Aug 2015 02:25 #36764 by randal flagg
sorry this is windows 10 right click has different settings
11 Aug 2015 02:27 #36765 by randal flagg
sweet v977 worked but still cant download v120 sends me to random webpage
11 Aug 2015 07:54 #36770 by TomPeer
Strange, i have windows 10 and right mouse works fine.
But if al the above links don't work then go to index / model config and find "walkera cp helicopters"
there are several, for beginners, for 3d and more. All made by TomZ.
good luck
Time to create page: 0.284 seconds
