DEVOF12E NOT BOOTING
15 Aug 2015 16:58 #36918 by sa
DEVOF12E NOT BOOTING was created by sa
Can anyone please help me.
My devof12e is not working, I mean its not displaying anything. Its turning on for just 2 seconds displaying in the screen like "devention-saving-please waiting" and turning off immediately. Now what shall i do. please help. It would be a great help....
15 Aug 2015 23:28 #36926 by dc59
Replied by dc59 on topic DEVOF12E NOT BOOTING
It seems "LOW BATTERY WARNING" has been triggered.
1, Find a higher voltage battery of TX and replace it.
2, Edit tx.ini find and edit or add this string "batt_critical=8000"
"8000" means low voltage set to 8.0V .
26 Aug 2015 15:19 #37216 by sa
Replied by sa on topic DEVOF12E NOT BOOTING
Brother please help me ..It did not work again. I replaced batteries but i still see these messages.
26 Aug 2015 23:53 #37227 by dc59
It looks like FW installation not complete, try to install it again and make sure every step is correct!
27 Aug 2015 03:23 #37231 by sa
Brother, I did it, it installed. It got a message too while upgrading. it shown a message that successfully upgraded. But i am facing this problem still.. Please help with any other solution.
27 Aug 2015 05:52 #37232 by dc59
I will let you know if I can reproduce your problem on my F12E!!
31 Aug 2015 02:45 - 31 Aug 2015 02:46 #37322 by dc59
@sa
Did you select all options when you upgraded F12E?
Last edit: 31 Aug 2015 02:46 by dc59.
31 Aug 2015 03:49 #37324 by sa
Thank you for the reply. I don't remember the settings. I will check once again tonight and will let you know.
01 Sep 2015 04:23 #37347 by sa
Dear Brother,
I installed upgrade tools of version 2.3.1. And i cannot view these settings in it. But it shows in other tabs and I am unable to select those options like format, library etc. while installing. Can you provide me the link of this installer which you have shown me in screenshot(version 0.8.0 ) also the set up files to install. I will try with those things and hope this may work.
Thank you
01 Sep 2015 05:01 #37349 by dc59
sa wrote: Dear Brother,
Thank you
All you need is here
www.deviationtx.com/downloads-new/category/161-dfu-usb-tool
01 Sep 2015 14:52 #37359 by sa
Yes, Thank you. I am going to give a try now
02 Sep 2015 03:52 #37369 by sa
I tried last night, please see the attached screenshot. I cannot see the devention f12e found here. I can see the word unknown. I am unable to install the DFU USBDrv installer 1.1. Is that the problem why i am unable to see.
I guess its not installing because my OS is win 10 pro. Is that the problem? should I try this in win 7 all these? Also if the upgrade is successful do you suggest me to format it or its not necessary?
Thank you.
02 Sep 2015 05:12 #37370 by dc59
I use WIn7 pro 32bit OS,I never used Win 10 ....... :(
If you Installed DFU USB drive correctly ,you should find 'STM DFU(WiUSB)' in your Device Manager.
Then you can find F12E in Uploader!!
Maybe this driver is not compatible with Win10, I'm not sure :huh:
02 Sep 2015 05:15 #37371 by sa
Sure, I will try on Win 7 again, mine is 64 bit anyway. I think it will be compatible with it.
04 Sep 2015 06:20 #37425 by sa
:( bro, my time is running too bad now a days, Actually I upgraded to win10. As this software did not work so I reverted back to Win 7 and my keyboard and mouse stopped working. i removed the battery in cpu for 5 mn and tried and still did not work . So I will format my pc this weekend and try with deviation tools again. May God help me. And strange thing I found a new screen displaying again in my devof12e about Usb. I attached the screenshot. But again that screen gone back and displayed old message like "devention saving...please waiting" when I plugged the usb. Anyway I will try upgrading again after I format my pc. Thank you.
05 Sep 2015 03:20 #37457 by dc59
sa wrote: :( bro, my time is running too bad now a days, Actually I upgraded to win10. As this software did not work so I reverted back to Win 7 and my keyboard and mouse stopped working. i removed the battery in cpu for 5 mn and tried and still did not work . So I will format my pc this weekend and try with deviation tools again. May God help me. And strange thing I found a new screen displaying again in my devof12e about Usb. I attached the screenshot. But again that screen gone back and displayed old message like "devention saving...please waiting" when I plugged the usb. Anyway I will try upgrading again after I format my pc. Thank you.
Regarding "devention saving...please waiting" problem, it's same problem from low battery voltage setting I had mention few weeks ago,but I still have no idea about other problems you have .... :(
07 Sep 2015 06:54 #37527 by sa
Bro,
I have installed the uploader and usb tools. It has detected the usb in device manager as you said. And I tried upgrading firmware. I still see unkown in the uploader. please watch the video. Anyways I selected the zip file and tried installing and I can see a green bar bottom in uploader and I have no idea that its upgrading or not. I left for so long but I cannot see any message showing "successfully upgraded". Is anything I am missing? And regarding tx.ini, adding string "batt_critical=8000". I can unzip the files and see the tx.ini file. But how can I update this in transmitter? Do i need to format it by holding ENT button + power on button and paste the unzip files in it? As I am unable to upgrade firmware can I format it first and try to upgrade it. Please help.
07 Sep 2015 08:25 - 07 Sep 2015 08:27 #37529 by dc59
It looks the driver for uploader didn't be installed correctly!
That driver is used for Walkera Devention DfuSe USB Upgrade Tools,not for Deviation Upload.
Did you install driver like this:
Turn off F12E power
1, download "DFU USBDrv Installer-1.1" and un-zip it to a directory.
2, Run "DFU USBDrv Installer-1.1" in that directory.
3, Follow these steps:
4, Connect F12E to PC with USB cable and then turn on F12E power
5, You should find this in Device Manager
6, Run "DeviationUpload-0.8.0" you can find "Devo F12E"
Last edit: 07 Sep 2015 08:27 by dc59.
07 Sep 2015 08:29 #37530 by dc59
Done!
07 Sep 2015 08:35 #37531 by dc59
Regarding voltage alarm issue:
Edit and Save the tx.ini directly in FW ZIP file before you upgrade firmware.
"2, Edit tx.ini find and edit or add this string "batt_critical=8000"
"8000" means low voltage set to 8.0V ."
Time to create page: 0.658 seconds
