Percentage timer Devo 10
22 Aug 2015 14:43 - 24 Aug 2015 21:00 #37142 by mario123
Percentage timer Devo 10 was created by mario123
Is there a percentage timer in the deviation firmware? I found something that looks and behaves like that it's called "cntdn-prop" but the problem is it counts -100% as prop is moving.
It thinks the prop is not moving when I'm at 0%, which is actually half power. So how do I set this up the right way?
Thanks in advance.
Mario
Last edit: 24 Aug 2015 21:00 by mario123.
23 Aug 2015 10:11 #37162 by mwm
Replied by mwm on topic Percentage timer Devo 10
This is documented in the manual: deviationtx.com/manuals/html-devo10/ch_m...l#timers-std-adv-gui
You need to use a virtual channel as Control, and mix your throttle (or whatever you want to use) to values of 0 to 100.
23 Aug 2015 10:39 #37164 by mario123
Replied by mario123 on topic Percentage timer Devo 10
Thank you. Know it works like a charm.
Time to create page: 0.058 seconds
