Devo 7e not working
- christx
10 Sep 2015 11:02 #37623
by christx
Devo 7e not working was created by christx
When I switch on the power button nothing happens: nothing on the screen and no sound. I tested my batteries they are ok.
I Wonder if it's a common bug?
Any idea is welcome!
10 Sep 2015 17:16 #37638
Replied by mwm on topic Devo 7e not working
No, it's not common. It could be a firmware issue though.
Take out the battery for 5 minutes or more, then try turning it on in dfuse mode. That should work even if the firmware is busted. If that works, you can try power cycling to normal mode, or just re-install deviation. If you can't boot in dfuse mode, then it's liable to be a hardware issue of some sort.
- christx
10 Sep 2015 18:01 #37642
by christx
Replied by christx on topic Devo 7e not working
How do I run the radio in dfuse mode? I am afraid i need more informations!
Thank you!
Thank you!
- greenfly
10 Sep 2015 18:53 #37643
by greenfly
Replied by greenfly on topic Devo 7e not working
Hold the EXT button down while you turn the transmitter on.
- christx
11 Sep 2015 08:20 #37654
by christx
I tried the dfu mode but nothing happens. I Will open my radio soon.
- Richard96816
12 Sep 2015 08:48 #37677
by Richard96816
Replied by Richard96816 on topic Devo 7e not working
Sounds like it's time to re-flash the bootloader ...
www.deviationtx.com/forum/6-general-disc...-7e-bootloader#34250
It should be possible to do without the stlink, but not sure how that's done with Devo.
Re-flashing brought mine back to life.
- christx
15 Sep 2015 16:08 #37783
by christx
Sounds pretty difficult but interresting, i am going to order a St-link.
If it's an harware problem what should i check first inside my tx?
- christx
16 Sep 2015 08:21 #37801
by christx
Could someone please tell me where to buy an St link. Do I need anything else (driver for example)?
Thank you!
Thank you!
- Richard96816
- christx
16 Sep 2015 10:45 #37803
by christx
Merci Richard!
I ordered one.
I ordered one.
- christx
05 Oct 2015 07:28 #38432
by christx
I post this mail Just to say I opened my radio and took off the modules. The radio now Works well.
Time to create page: 0.068 seconds
- Devo 7e not working
