DFUSe Windows 10 x64
- -=Hubi-Dirk=-
11 Sep 2015 15:02 - 11 Sep 2015 15:03 #37661
by -=Hubi-Dirk=-
DFUSe Windows 10 x64 was created by -=Hubi-Dirk=-
Hi Guys,
may it is asked somewhere but I didn’t find it.
I got Windows 10 x64 running and want to install a new Nightly for my 8s. STM32 DFU USB Device appears when I switch the TX on, but the DFU Software didn´t recognised the TX.
Any suggestions are appreciated.
Thank and bye
Dirk
Thank and bye
Dirk
Last edit: 11 Sep 2015 15:03 by -=Hubi-Dirk=-.
12 Sep 2015 18:19 #37692
Replied by mwm on topic DFUSe Windows 10 x64
Which DFU software are you using?
You did turn the Tx back on in DFU mode, right?
- -=Hubi-Dirk=-
12 Sep 2015 19:17 - 12 Sep 2015 20:25 #37697
by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic DFUSe Windows 10 x64
Hi mwm,
thanks for your reply. By holding EXT I turn the 8s on. This is not the first time I use the DFU mode. On an other System (Win 7 U 32) I got no problems. I use the Version 2.0 downloaded form the Walkera ftp-Server: walkera.com/en/upload/upgrade/
Thanks in advance
Dirk
Thanks in advance
Dirk
Last edit: 12 Sep 2015 20:25 by -=Hubi-Dirk=-.
- Gerhard_H
18 Sep 2015 06:24 #37838
by Gerhard_H
Replied by Gerhard_H on topic DFUSe Windows 10 x64
Hi Dirk !
Problem fixed ?
I ask because I also want to go to Win10x64.
Regards
Gerhard
Problem fixed ?
Regards
Gerhard
- aMax
18 Sep 2015 10:02 #37845
by aMax
Replied by aMax on topic DFUSe Windows 10 x64
You certainly know that the 64bit OS will use signed drivers only. On a 32 bit Windows you may force install an unsigned
one, but no way on a 64bit system.
Additional to that, Win 10 uses secure boot, therefore I am in doubt that it will work.
Best work around, keep your older maschine or try at least install Win10 as dual boot (best way may be to keep the older OS on a separate HD).
That's the way how I did it all the years not to run into trouble.
- -=Hubi-Dirk=-
18 Sep 2015 17:18 - 18 Sep 2015 17:18 #37854
by -=Hubi-Dirk=-
Hi Gerhard,
no sorry, I worked on it but can´t find a way. When I start the dpinst_ia64 (driver section) only the message came "Fehler bei Programmausführung" (Error starting Program). This way was discribed for Windows 8 but do not work with Windows 10.
As aMax said, keep an older system. Fortunaly I got an old Laptop running on Win7 x32.
Last edit: 18 Sep 2015 17:18 by -=Hubi-Dirk=-.
- Bullfrog
18 Sep 2015 19:59 #37856
by Bullfrog
Replied by Bullfrog on topic DFUSe Windows 10 x64
Hi
I´m running Dfuse USB Upgrade Tools v2.31 on my Win10 Pro 64bit system (upgraded from Win7 Ult. 64bit) without any problems.
Maybe the old Dfuse 2.0 version on Walkera download page is the problem.
v2.31 downloaded from: walkera-fans.de/downloads/
Give it a try.
Give it a try.
- Gerhard_H
19 Sep 2015 02:49 #37869
by Gerhard_H
@Bullfrog
Thx a lot for advice, sounds good !
@Hubi-Dirk & aMax
Both an additional laptop or a dual boot system will help, but as Bullfrog says the last Dfuse version should solve the problem.
@Hubi-Dirk & aMax
- -=Hubi-Dirk=-
19 Sep 2015 06:29 #37872
by -=Hubi-Dirk=-
Hi Bullfrog,
thanks for your help, but also the 2.31 will not work. The program started but don´t recon the 8s.
Maybe it depends on following. I have made a brand new installation of Windows 10 Pro x64 on a new m.2-Drive. No upgrade, I transfer only the key for activation of Windows 10.
So when you upgrade your system, do you install dfuse before or after the upgrade?
- Bullfrog
19 Sep 2015 07:24 #37873
by Bullfrog
Hi
Dfuse 2.31 was on the system before I did the upgrade to Win10.
Today I´ve installed Dfuse on a Win 10 Pro x64 computer (also upgraded from Win7) with no Dfuse before, and the TX will not recognised by Dfuse as reported from you.
Started Computer, Dfuse and TX several times, no change.
But I got it to run:
While Dfuse Software running and TX in programming mode, I removed the USB cable for a few seconds, then connect it back and in that moment device was shown in Dfuse. Since then, no problems in finding TX by Dfuse on that system. No idea why, but it works fine even after some restarts of computer, Dfuse and TX.
- -=Hubi-Dirk=-
19 Sep 2015 08:06 #37874
by -=Hubi-Dirk=-
Hi Bullfrog,
thanks again for your great help. I test it as you told me but there is no connection between dfuse and 8s. When i pluged the 8s on the DFU Device will been shown at the Device Manager as you can see at the attached picture. Un- and replugging does not change the situation tested with more and less time in between.
- Bullfrog
19 Sep 2015 08:32 - 19 Sep 2015 08:40 #37875
by Bullfrog
Last edit: 19 Sep 2015 08:40 by Bullfrog.
- Gerhard_H
19 Sep 2015 09:02 #37876
by Gerhard_H
Hi Dirk !
Looks like an USB issue . . .
Did you try different USB ports ? Hub ?
I definitely hate USB, it still doesn't work as it should (plug and pray . . .)
- aMax
19 Sep 2015 10:09 #37883
by aMax
Try to get "USBDevinfo" (download from net) running. That will give you more information about your driver's state.
- -=Hubi-Dirk=-
19 Sep 2015 14:54 #37888
by -=Hubi-Dirk=-
Thanks to all of you for your help!
USBDeview is now running, attached you will find a report. It is not possible to enable this device, also as Administrator.
Any help is apreciated, thanks in advance.
Best
Dirk
Best
Dirk
- aMax
19 Sep 2015 15:31 #37889
by aMax
OK, last try with version 2.31 ( >>>>>Walkera Fans / DE)....
Btw, why did you cut the picture at right side? Would have been interesting if windows had an ID for that device.
- -=Hubi-Dirk=-
19 Sep 2015 16:55 - 19 Sep 2015 16:55 #37892
by -=Hubi-Dirk=-
Sorry aMax, here is the second part of the table. Version 2.31 is installed since this morning.
Last edit: 19 Sep 2015 16:55 by -=Hubi-Dirk=-.
- aMax
19 Sep 2015 17:11 - 19 Sep 2015 18:04 #37893
by aMax
The instance ID is the same as with winXP and win7, but windows seems to use it's own driver instead the one from the install packet.
The drivername you will have to find, is "STTube30" , which is the dfu driver. The installed one, looks like a successor of the "usbstor.sys", which is for the flashdrive.
What happens if you press ENT while power on the tx.?
Edit:
The last idea on this, you may get the driver with a newer installation file of the "Flash_Loader_Demontrator" from STMiroelectronics
into your system.
Edit2: I have found the WinUSB.sys on my system, but here it is for the STLink dongle.
Edit:
into your system.
Last edit: 19 Sep 2015 18:04 by aMax. Reason: typo
- -=Hubi-Dirk=-
19 Sep 2015 17:44 - 19 Sep 2015 17:45 #37894
by -=Hubi-Dirk=-
Ok, i found the driver in the section Driver/x64/STTube30.sys
Now, how can import that driver to the system?
And to your question: I always press Enter and power on the TX.
Last edit: 19 Sep 2015 17:45 by -=Hubi-Dirk=-.
- aMax
19 Sep 2015 17:55 - 19 Sep 2015 18:05 #37895
by aMax
No, "EXT" and poweron leads to the DFU mode.
Edit:
....so Jung, wo bleibt das feedback...?
Edit:
Last edit: 19 Sep 2015 18:05 by aMax.
Time to create page: 0.175 seconds
- DFUSe Windows 10 x64
