What if I manually replace a protocol (Devo 7e)
18 Sep 2015 03:05 #37835 by T.N.
It may be a silly question but I'll ask anyway. Apologies if it's already been asked before.
There are many protocols in the 7e that I don't think I'll ever use. So what would happen if I replace one with a new protocol e.g. MTxx without recompiling as new build? Would it work? I guess it will load but not sure if it will work. I might try it out over the weekend.
19 Sep 2015 00:25 #37858 by mwm
You have to make sure it's built against the same version of the firmware as you are using.
There's not really much point in deleting the unused protocol files. They live in the file system space, which isn't really an issue yet. I suspect they'd still show up in the list of protocols, and you'd just crash the Tx when you tried to load them. or maybe you'd get a failure warning - I haven't checked the code.
