Battery status bar
19 Sep 2015 09:18 #37879 by Gerhard_H
Battery status bar was created by Gerhard_H
Hi !
The status of the battery normally is indicated by a number of volts, which I don't like so much.
I always have to calculate what the number means - yes, I know, I'm an i...
Isn't it possible to get an (additional) information (a bar) which tells me at a glance the status of the battery ?
Tia
Gerhard
19 Sep 2015 15:50 #37890 by mwm
Replied by mwm on topic Battery status bar
No, you can't get that. Not clear how it would be implemented anyway, as the fully charged voltage and voltage decay curve both vary depending on what kind of battery you have. I know of people using LiPO's, LiFE, NiMH and NiCd, and people probably use alkaline batteries when they start out. All the Tx can sense is the voltage level, and it knows how much is required to safe files - so those are the things it tells you about.
19 Sep 2015 22:05 #37902 by Gerhard_H
Replied by Gerhard_H on topic Battery status bar
OK, thx anyway !
