Simulator cable not working after FW upgrade
20 Sep 2015 19:07 #37908 by mm-de
thanks for the great FW, got my V120d02s set up so far on a DEVO 10.
Only thing that won't work is the simulator cable.
On my old Devo-7 I just plug it in, switch on the transmitter and it will show PC connection. On the Devo 10 with Deviation nothing changes compared to normal startup.
Could not find any special setting, did I miss something?
Marius
20 Sep 2015 21:00 #37909 by mwm
The setting you want is in the protocol selection of the model setup. You want to use either PPM for conventional sims or USBHID for sims that can work with a game controller.
20 Sep 2015 22:24 #37911 by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Simulator cable not working after FW upgrade
Just make a new model specifically for sims, with the protocol selected; saves things getting mixed up and maybe accidentally wrecking a "real" model's settings.
Time to create page: 0.408 seconds
