- Simulator cable not working after FW upgrade
- mm-de
20 Sep 2015 19:07 #37908
by mm-de
Simulator cable not working after FW upgrade was created by mm-de
thanks for the great FW, got my V120d02s set up so far on a DEVO 10.
Only thing that won't work is the simulator cable.
On my old Devo-7 I just plug it in, switch on the transmitter and it will show PC connection. On the Devo 10 with Deviation nothing changes compared to normal startup.
Could not find any special setting, did I miss something?
Marius
Marius
20 Sep 2015 21:00 #37909
Replied by mwm on topic Simulator cable not working after FW upgrade
The setting you want is in the protocol selection of the model setup. You want to use either PPM for conventional sims or USBHID for sims that can work with a game controller.
- RoGuE_StreaK
20 Sep 2015 22:24 #37911
by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Simulator cable not working after FW upgrade
Just make a new model specifically for sims, with the protocol selected; saves things getting mixed up and maybe accidentally wrecking a "real" model's settings.
Time to create page: 0.617 seconds
