- Possibility in adding vibrate function in Devo12S
- richardclli
23 Sep 2015 02:18 #37981
by richardclli
Possibility in adding vibrate function in Devo12S was created by richardclli
I have modded my Devo 8S successfully, just thinking if I can mod the Devo 12S with the vibrate function as well. Any ideas in how to make the vibrate hardware connected to the main board?
- Epyon
23 Sep 2015 03:29 #37986
by Epyon
Replied by Epyon on topic Possibility in adding vibrate function in Devo12S
Sorry, I can't help you,...........but you could help me
I just inquired about the 8s vibration mod. Is it supported by standard builds. That's what the "enable-haptic=1" is for in hardware.ini? It connects to pin 83, right? Thanks, and sorry.
- richardclli
23 Sep 2015 03:53 #37992
by richardclli
Replied by richardclli on topic Possibility in adding vibrate function in Devo12S
Actually, I am not sure if there are any unused pins in Devo12S that can be used to work out a vibrate mod, is there anybody who know the hardware of Devo12S can help a bit?
- Block137
25 Sep 2015 05:06 #38041
by Block137
Replied by Block137 on topic Possibility in adding vibrate function in Devo12S
At least make it vibrates alongside with buzzer?
Time to create page: 0.220 seconds
