DHD D1 QUADCOPTER DRONE Which Protocol?
- mmakam2
29 Sep 2015 22:59 #38239
by mmakam2
DHD D1 QUADCOPTER DRONE Which Protocol? was created by mmakam2
Hey all,
I just picked up a DHD D1 Drone. It is suppose to bind with the CX10 protocol, but I tried green, blue-a, and DM007 with no avail.
I opened up the rX, and it has a xn297 v1.0 printed on it. It also has CX-10 START on the controller board. It seems it should bind but its not.
Any idea? Do I need a specific fixed id or something?
- beardyman
29 Sep 2015 23:11 #38240
by beardyman
Replied by beardyman on topic DHD D1 QUADCOPTER DRONE Which Protocol?
I have the Floureon FX-10, which is allegedly identical, and I initially had a lot of trouble binding mine (using the CX-10 protocol, blue-A). Now I switch on the quadcopter first, and wait several seconds before turning on the transmitter, and it seems to bind quite reliably this way, I don't know why. I'm not using fixed ID.
It seems like good practice to me to turn on the transmitter first, but that hasn't worked for me with this quad.
- mmakam2
02 Oct 2015 02:38 #38338
by mmakam2
Replied by mmakam2 on topic DHD D1 QUADCOPTER DRONE Which Protocol?
HOLY COW, it works!
Thanks man! Do you have a model for me? Everything worked with the default settings, but do you know how to switch between modes, if its even possible? Flips would be even more amazing.
- beardyman
02 Oct 2015 14:38 #38354
by beardyman
I've attached my ini file, but it is for a Devo7e modded with 2x3 extra switches. Flips are controlled by channel 5 and headless mode by channel 6. Hope it helps!
- Multirotor Go
18 Dec 2015 02:18 #41012
by Multirotor Go
Replied by Multirotor Go on topic DHD D1 QUADCOPTER DRONE Which Protocol?
Is it necessary to copy all the ???????????????????etc ? Or that is just some kind of error?
How can I implement it for 7e with just stock two position switches? I am trying to get the highest rates with out the annoying headless.
thanks
thanks
Time to create page: 0.300 seconds
- DHD D1 QUADCOPTER DRONE Which Protocol?
