KN protocol broken in latest nightly?
09 Nov 2015 20:38 - 09 Nov 2015 20:39 #39783 by Moeder
Replied by Moeder on topic KN protocol broken in latest nightly?
Ok, here we go:
devo10
devo7e
Also, please note the "dyntrim" feature is available in the protocol options in the more recent builds, which uses the trim channels to increase servo throw.
Last edit: 09 Nov 2015 20:39 by Moeder.
10 Nov 2015 00:03 #39789 by beardyman
Replied by beardyman on topic KN protocol broken in latest nightly?
Yup, still working fine on both 7e and 10! I haven't yet tried using channels 9-11 or dyntrim, but everything else seems fine. :)
24 Nov 2015 06:13 #40332 by davidwyl
Replied by davidwyl on topic KN protocol broken in latest nightly?
Moeder wrote: Ok, here we go:
devo10
devo7e
finally get to try this out. tried on my D7e & D10 (both with MM1.3), now i can bind with my v977 ....good job B)
thanks a lot for hardwork.
wondering why is this not make it to the nightly build yet? :)
24 Nov 2015 08:22 #40334 by Moeder
davidwyl wrote: wondering why is this not make it to the nightly build yet? :)
The code change has been merged to the main repository on Nov 11, so it should be included in nightly builds from Nov 12.
24 Nov 2015 18:18 #40344 by beardyman
Nightlies seem to be broken again, unfortunately. :(
http://www.deviationtx.com/forum/3-feedback-questions/4680-nightly-builds
24 Nov 2015 20:28 #40349 by Moeder
Ok, I didn't check for that, as I only run my own custom builds. But I guess it will be just a matter of a couple of days until we have recent nightlies again. The build in this thread is only 2 weeks old, there haven't been any substantial changes since then.
25 Nov 2015 02:28 #40362 by mwm
Replied by mwm on topic KN protocol broken in latest nightly?
Well, "no substantial changes" isn't the question - there are changes, so it should be building new nightlies. That we aren't means the build is failing. So until it gets fixed, no new nightly builds. :(
25 Nov 2015 18:09 #40380 by Moeder
Yes, of course. I haven't looked into why the build fails, IIRC someone in the thread mentioned it is the f12. Shouldn't we change the automatic build script, so the models will be built separately and one down doesn't take the others with it? Guess I should move the question to the other thread....
25 Nov 2015 23:08 #40384 by mwm
I'm not sure changing it so that one model doesn't stop them all is a good idea - do we really want "the latest nightly" to be different versions for different transmitters?
I don't know if the nightly build script is even something we can change, or if it needs FDR or PB to do it.
26 Nov 2015 05:52 #40396 by FDR
Replied by FDR on topic KN protocol broken in latest nightly?
Only PB can do it...
Time to create page: 0.512 seconds
