Devo 10 only shows up on base flight
- Gameboy138
04 Oct 2015 01:40 #38409
by Gameboy138
Devo 10 only shows up on base flight was created by Gameboy138
I just received my quad from mini brothers I have a devo10, naze 32 acro, and a orangerx r410x spektrum jr receiver. I hacked the devo 10 and I can use dsmx . I completely bind and then connected to base flight . Every thing is already set up accept for profile which is the buzzer and acro . My devo 10 shows that the controls work normally my motors only come on when I check test them on my computer.
I unplug the quad and no reaction . I can not figure out what in doing wrong . Ir can not figure out what I'm suppose to do to actually get my mini quadcopter to even move.
- Jasenk
05 Oct 2015 23:31 #38458
by Jasenk
-Jasen
Replied by Jasenk on topic Devo 10 only shows up on base flight
Just a shot, but did you calibrate sticks and Aux's? Maybe something is showing to high and won't enable the motors. Like I said, just a shot. Or try to trim the throttle down more. Other than that, I'm out because I am not familiar with you model.
-Jasen
- richardclli
06 Oct 2015 02:36 #38460
by richardclli
Replied by richardclli on topic Devo 10 only shows up on base flight
I have tried similar problem. You may need to extend the throttle range in the channel settings to make it works.
- Gameboy138
06 Oct 2015 03:30 #38463
by Gameboy138
Replied by Gameboy138 on topic Devo 10 only shows up on base flight
Well I finally got it . I had to go on gui options and change them tip standard.
Then I noticed the beeps when I had throttle all the way up.
I got lucky and toned it right.
After the 3rd beep throttle down and to the right corner in so happy hag this thing for two weeks .
Now I hope the orange rx I have goes far enough . I'm worried about the short antennas.
Time to create page: 0.293 seconds
- Devo 10 only shows up on base flight
