[BUG] problems with latest nightly
04 Oct 2015 11:54 - 04 Oct 2015 11:55 #38414 by matrixFLYER
[BUG] problems with latest nightly was created by matrixFLYER
This is the bug.
1) Load a new model
2) delete the second timer from main page config
now the bug occurr.
3) check you main page
the tx power box is duplicated and you can't delete it, just move it around.
Tested with latest nightly and with nightly from 19 june 2015
Last edit: 04 Oct 2015 11:55 by matrixFLYER.
05 Oct 2015 00:08 #38425 by mwm
Replied by mwm on topic [BUG] problems with latest nightly
Looks like this is related to the "Can't delete a box" bug. At least, it shows up when I try it in the emulator, and not with a version that has that fix.
I've uploaded test builds deviationtx.com/downloads-new/category/227-mwm-fixboxdelete with that fix in place. Let me know if it works for you, and if so I'll go ahead and merge it into default. But I'd like at least one more person to review it before then.
05 Oct 2015 04:43 - 05 Oct 2015 04:54 #38428 by richardclli
Replied by richardclli on topic [BUG] problems with latest nightly
I think the fix is quite obvious. Well there is a work around for the current nightly. Try moving the deleted box to X=0 and Y=0 and it will disappeared.
Last edit: 05 Oct 2015 04:54 by richardclli.
05 Oct 2015 15:14 - 05 Oct 2015 15:14 #38437 by matrixFLYER
Replied by matrixFLYER on topic [BUG] problems with latest nightly
mwm wrote: Looks like this is related to the "Can't delete a box" bug. At least, it shows up when I try it in the emulator, and not with a version that has that fix.
So quik fix!! It works! Tested on Devo10. Is this based on latest nightly?
Last edit: 05 Oct 2015 15:14 by matrixFLYER.
05 Oct 2015 18:27 #38444 by mwm
Yes, this is the code from the latest nightly along with the suggested patch. I'll merge it in the near future, which will trigger a new nightly build.
14 Oct 2015 19:36 #38814 by Cereal_Killer
Replied by Cereal_Killer on topic [BUG] problems with latest nightly
Just confirming that I have recreated this bug without issue on the 10/01 nightly (i.e. followed the exact steps listed above) and did experience it. 7E build 2cde795 (I will be updating to the newest nightly again tonight, I see it's already solved, just wanted to report my findings).
  • mabxhrc
  • mabxhrc's Avatar
  • At each flight, a new brain connection...
29 Oct 2015 00:58 - 30 Oct 2015 22:38 #39332 by mabxhrc
Replied by mabxhrc on topic [BUG] problems with latest nightly
Greetings!
This issue occur at deviation-devo8-v4.0.1-583c468 nighlty on devo 8S
You can enter in usb mode without problem, copy files etc. When you press "ent" to get out, the interface enter on "freeze" condition. The only way to correct this is turn off/on the radio.
About navigation/settings/modifications: It not possible to do modifications on curves (throttle/expo/cyclic etc), so I go back to the stable version.
Regards
Last edit: 30 Oct 2015 22:38 by mabxhrc. Reason: New behavior find after do tests.
04 Nov 2015 14:21 #39549 by Cereal_Killer
The problem described above is not a bug, that's the intended operation. The usb drive must be ejected before removal and the tx power cycled.
Time to create page: 1.086 seconds
