[BUG] problems with latest nightly
- matrixFLYER
04 Oct 2015 11:54 - 04 Oct 2015 11:55 #38414
by matrixFLYER
[BUG] problems with latest nightly was created by matrixFLYER
This is the bug.
1) Load a new model
2) delete the second timer from main page config
now the bug occurr.
3) check you main page
the tx power box is duplicated and you can't delete it, just move it around.
Tested with latest nightly and with nightly from 19 june 2015
1) Load a new model
now the bug occurr.
Last edit: 04 Oct 2015 11:55 by matrixFLYER.
05 Oct 2015 00:08 #38425
Replied by mwm on topic [BUG] problems with latest nightly
Looks like this is related to the "Can't delete a box" bug. At least, it shows up when I try it in the emulator, and not with a version that has that fix.
I've uploaded test builds deviationtx.com/downloads-new/category/227-mwm-fixboxdelete with that fix in place. Let me know if it works for you, and if so I'll go ahead and merge it into default. But I'd like at least one more person to review it before then.
- richardclli
05 Oct 2015 04:43 - 05 Oct 2015 04:54 #38428
by richardclli
Replied by richardclli on topic [BUG] problems with latest nightly
I think the fix is quite obvious. Well there is a work around for the current nightly. Try moving the deleted box to X=0 and Y=0 and it will disappeared.
Last edit: 05 Oct 2015 04:54 by richardclli.
- matrixFLYER
05 Oct 2015 15:14 - 05 Oct 2015 15:14 #38437
by matrixFLYER
So quik fix!! It works! Tested on Devo10. Is this based on latest nightly?
Replied by matrixFLYER on topic [BUG] problems with latest nightly
mwm wrote: Looks like this is related to the "Can't delete a box" bug. At least, it shows up when I try it in the emulator, and not with a version that has that fix.
Last edit: 05 Oct 2015 15:14 by matrixFLYER.
05 Oct 2015 18:27 #38444
Yes, this is the code from the latest nightly along with the suggested patch. I'll merge it in the near future, which will trigger a new nightly build.
- Cereal_Killer
14 Oct 2015 19:36 #38814
by Cereal_Killer
Replied by Cereal_Killer on topic [BUG] problems with latest nightly
Just confirming that I have recreated this bug without issue on the 10/01 nightly (i.e. followed the exact steps listed above) and did experience it. 7E build 2cde795 (I will be updating to the newest nightly again tonight, I see it's already solved, just wanted to report my findings).
- mabxhrc
- At each flight, a new brain connection...
29 Oct 2015 00:58 - 30 Oct 2015 22:38 #39332
by mabxhrc
Replied by mabxhrc on topic [BUG] problems with latest nightly
Greetings!
This issue occur at deviation-devo8-v4.0.1-583c468 nighlty on devo 8S
You can enter in usb mode without problem, copy files etc. When you press "ent" to get out, the interface enter on "freeze" condition. The only way to correct this is turn off/on the radio.
About navigation/settings/modifications: It not possible to do modifications on curves (throttle/expo/cyclic etc), so I go back to the stable version.
Regards
Regards
Last edit: 30 Oct 2015 22:38 by mabxhrc. Reason: New behavior find after do tests.
- Cereal_Killer
04 Nov 2015 14:21 #39549
by Cereal_Killer
The problem described above is not a bug, that's the intended operation. The usb drive must be ejected before removal and the tx power cycled.
Time to create page: 0.801 seconds
- [BUG] problems with latest nightly
