DEVO7E RANGE MOD with conductive ink
- beyondthesea
07 Oct 2015 08:57 - 07 Oct 2015 09:08 #38512
by beyondthesea
DEVO7E RANGE MOD with conductive ink was created by beyondthesea
NOW, I got conductive pen in hand
For Devo7E RANGE MOD
Have to remove diode then draw line ??
or
just draw line?
IS THE SAME?
or
just draw line?
IS THE SAME?
Last edit: 07 Oct 2015 09:08 by beyondthesea.
- Durete
07 Oct 2015 13:31 #38525
by Durete
Replied by Durete on topic DEVO7E RANGE MOD with conductive ink
You don't need to remove the diode, only bridge above the diode pads.
I advice to you to "scratch" a little bit the upper side of the solder points, to adhere better the conductive ink.
Also, you need to wait about 24 hours to dry the conductive ink.
Be careful!
Be careful!
- beyondthesea
07 Oct 2015 23:40 #38545
by beyondthesea
Replied by beyondthesea on topic DEVO7E RANGE MOD with conductive ink
Thanks I'll test range then try!!!
- Richard96816
11 Oct 2015 19:32 #38746
by Richard96816
Replied by Richard96816 on topic DEVO7E RANGE MOD with conductive ink
You might want to temporarily apply tape all around to reduce the possibility of getting ink in undesirable places. Cleaning with alcohol beforehand might be helpful too.
Sorry for the late response.
- sledgehammer1570
15 Oct 2015 06:08 #38837
by sledgehammer1570
Replied by sledgehammer1570 on topic DEVO7E RANGE MOD with conductive ink
Is there a way to get a hint somehow if the range mod is succesful? I had huge problems executing this mod. I haven't yet got any other birds than nrf24l01 based flyers. I'm waiting a dsm2 protocol lemon-rx and a 250 fpv racer. For now, I can only hope for the best and fear for the worst.
- Durete
15 Oct 2015 06:25 #38838
by Durete
In my opinion, the only good test is a real test
I have even a 7e module with the Power Amplifier stage dead, and you can see voltage battery fluctuations as should be when working fine. But the module is dead
15 Oct 2015 09:28 #38843
Replied by mwm on topic DEVO7E RANGE MOD with conductive ink
Do a range test before and then after. You really ought to be doing range tests for every model as you add them anyway.
Bind the Tx to a model, then start walking away while moving something. Hopefully, something you can see! If you can't see it, then ask someone to watch the model, and wave at you when whatever you're moving stops moving. That tells you the range at which things will quit working.
- Durete
15 Oct 2015 10:33 - 15 Oct 2015 10:34 #38849
by Durete
Just finished some minutes ago a range mod for a buddy's Devo 7e.
We modified the hardware.ini file before bridge the diode (I think is a 10k resistor,not a diode).
With hardware.ini modified and without the diode bridge, we reach only about 15 cm using the range test option under Deviation firmware.
After we bridged the diode, we reach about 25 meters using the same "Range Test" option under Transmitter Menu.
We used an Orange R615X receiver in DSMX mode for this test.
Hope this info could be useful.
Last edit: 15 Oct 2015 10:34 by Durete. Reason: Add info.
- aMax
15 Oct 2015 10:46 #38851
by aMax
Replied by aMax on topic DEVO7E RANGE MOD with conductive ink
And what is it if you set 100 µW at the model section?
I never had 25m with a R615X at this stage.
- Durete
15 Oct 2015 11:01 #38853
by Durete
With range test option active, should be 100uw.
BTW, at about 25 meters the R615X start to blink sometimes, not too much, but don't loose bind. I guess loose bind near 35-40 meters, but can't test now.
You got better or worse range?
aMax wrote: And what is it if you set 100 µW at the model section?
- Durete
15 Oct 2015 11:03 #38854
by Durete
Tested now with my 7e, not with my buddy's 7e, and I got about the same range in range test (100uw)
- aMax
15 Oct 2015 11:21 #38856
by aMax
I never used "Rangetest", always set the 100uw. at the model section for the DSMX protocol.
What I can get for a solit connection is 12-13m( no flashing) and to have more range I have to use at least 300uw.
Some weeks ago I did a ground test to compaire to my CC2500 mod and gained around 330m at 100mW before the failsafe on the throttle channel kicked in.(used a servo to indicate this).
- Durete
15 Oct 2015 11:33 #38857
by Durete
I took my measuring tape, and you are right, about 13-15 meters without any blink.
I'm very bad guessing distances
I will check outside as soon as possible, because just finished to install a new 7e CYRF module.
(Short history, my CYRF module dead, and a nice guy from Deviation forum sent me one he pull out from his 7e
- aMax
15 Oct 2015 11:35 - 15 Oct 2015 11:38 #38858
by aMax
BTW, my cc2500 and the cheap F802 (BG) reached this distance test on ...10mW.....
Last edit: 15 Oct 2015 11:38 by aMax.
- Arakon
15 Oct 2015 17:25 #38871
by Arakon
Replied by Arakon on topic DEVO7E RANGE MOD with conductive ink
Someone on another forum measured the CC2500.. at 10mw, it actually outputs 88mw, so that's quite a lot (original frsky modules only output 60 mw, I think).
150mW - 120mW
100mW - 108mW
30mW - 100mW
10mW - 88mW
3mW - 73mW
1mW - 56mW
300uW - 41mW
100uW - 31mW
150mW - 120mW
100mW - 108mW
30mW - 100mW
10mW - 88mW
3mW - 73mW
1mW - 56mW
300uW - 41mW
100uW - 31mW
- aMax
15 Oct 2015 18:10 #38875
by aMax
Which one? The shielded 17dB or the unshielded 23dB?
Any link for this test?
- Arakon
15 Oct 2015 18:17 #38877
by Arakon
No further data but this, aside from the fact that the immersionrc RF meter was used via cable connection.
The module is the shielded one: www.banggood.com/CC2500-PA-LNA-Romote-Wi...F24L01-p-922595.html
- Fernandez
16 Oct 2015 07:49 #38905
by Fernandez
Replied by Fernandez on topic DEVO7E RANGE MOD with conductive ink
Just my input on making this mod.
Take some servo wire and strip it for few cm, then bend few (5) of the copper wires from the servo wire twist to thin bundle, but leave it to the long servo wire.
Tin the small bundle and solder to one side of the resistor, fold de bundle over the resistor solder it, while solder you can hold the cable in place, then when soldered, cut with small side cutter sticking out cable and the bridge is done.
Time to create page: 0.096 seconds
- DEVO7E RANGE MOD with conductive ink
