Devo 8s and PPM
- ronzer
08 Oct 2015 23:58 #38608
by ronzer
Devo 8s and PPM was created by ronzer
Is there a receiver that will work for ppm for my Devo 8s?
- magic_marty
09 Oct 2015 04:56 #38613
by magic_marty
Replied by magic_marty on topic Devo 8s and PPM
if you have deviation installed there is several dsm2/dsmx ppm receivers that will work..
- ronzer
09 Oct 2015 05:01 #38614
by ronzer
Replied by ronzer on topic Devo 8s and PPM
I have Deviation but cant find a ppm receiver.
- ronzer
09 Oct 2015 05:13 #38617
by ronzer
I found this Lemon Rx DSMX Compatible PPM 8-Channel , But what do I set my radio to?
09 Oct 2015 07:21 #38624
Replied by mwm on topic Devo 8s and PPM
If you are running the stock Walkera firmware, I believe the answer is "no".
If you have installed deviation but not otherwise modded the firmware, then you can there are some OrangeRx and LemonRx DSM Rx's that will bind with it and have PPM output.
If you've added the CC2500 module, then the FrSky D-series Rx's will bind to it and have PPM options.
Similar - but generally better in every way but availability - are the serial protocols: SBUS, SRXL and Spektrum's Satellite protocol. The newer OrangeRx Rx's can be had with either PPM or SBUS. There are a few Spektrum Rx's that do SRXL. The Spektrum Satellite protocol is only generated by the DSM "satellite" or "remote" Rx's. OrangeRx, LemonRx and Spektrum all make those. I'd avoid the satellite solutions for most uses.
All of these are DSM Rx's. In deviation, got to Model Menu, Model Setup, and change the protocol to DSMX.
- Thomas.Heiss
09 Oct 2015 08:21 - 09 Oct 2015 08:38 #38626
by Thomas.Heiss
Replied by Thomas.Heiss on topic Devo 8s and PPM
SRXL:
Spektrum AR9020
Spektrum AR7700 (new RX, spec explicitly states: serial RX with PPM+SRXL): www.deviationtx.com/forum/3-feedback-que...7e-transmitter#38541
8 channel PPM frame length:
www.deviationtx.com/forum/3-feedback-que...7e-transmitter#38551
www.deviationtx.com/forum/3-feedback-que...7e-transmitter#38621
Spektrum AR9020
Last edit: 09 Oct 2015 08:38 by Thomas.Heiss.
- magic_marty
09 Oct 2015 17:29 #38661
by magic_marty
I use one of the Lemon 8ch PPM on my Forza 450 Heli and it works really well with no problems thus far...
- ronzer
09 Oct 2015 17:54 #38663
by ronzer
Can you till me which one you have and how you set up you radio to make it work?
- jesmail
10 Oct 2015 18:43 #38692
by jesmail
Replied by jesmail on topic Devo 8s and PPM
The Walkera rx-703a will work with stock or Deviation firmware.
- magic_marty
11 Oct 2015 00:01 #38697
by magic_marty
This is the one i use on my Forza 450 with APM flight controller made it much easier to set up ...
www.ebay.com/itm/Lemon-Rx-MX-8-Channel-P...?hash=item2a4b3b9954
ronzer wrote: Can you till me which one you have and how you set up you radio to make it work?
- ronzer
11 Oct 2015 00:20 #38698
by ronzer
Thats the one I have been looking at but I will use it with the sat.
- magic_marty
11 Oct 2015 00:24 #38699
by magic_marty
For sure if you are going to use it on a carbon fiber frame use a Sat to improve reception...on my forza i have the rx on one side and the sat on the other ..
- ronzer
11 Oct 2015 00:39 #38701
by ronzer
Thanks Marty.
So I just set my radio to ppm ?
- magic_marty
11 Oct 2015 01:42 #38702
by magic_marty
No just bind it as DSMX and the receiver takes care of the PPM output ..
- ronzer
11 Oct 2015 01:49 #38703
by ronzer
So just keep the radio to DSMX?
- magic_marty
11 Oct 2015 02:16 #38705
by magic_marty
yes that is what i have mine set at...
- ronzer
Time to create page: 0.250 seconds
- Devo 8s and PPM
