need help with trim screen missing.
- Hot_Wheels
10 Oct 2015 14:04 #38691
by Hot_Wheels
need help with trim screen missing. was created by Hot_Wheels
So last night we updated my deco 8 to the latest 4.0.1 software but I no longer have a trim screen! I searched on here and went through all the modes I believe. I was able to set my model up but I can't see my trims to tell if there all centered. My home screen is blank and just shows model name and power output.
- richardclli
11 Oct 2015 00:31 #38700
by richardclli
Replied by richardclli on topic need help with trim screen missing.
You need to setup the screen again, you may tried to load from a template:
1. click into model setup
2. click "<-" button
3. click "+" button
4. Click "Load" button
5. Select "Default template"
Done! you have a default template screen loaded, you can edit it using the same screen.
3. click "+" button
- Hot_Wheels
11 Oct 2015 06:00 #38725
by Hot_Wheels
Replied by Hot_Wheels on topic need help with trim screen missing.
Um... I was hoping that would add the trim screen but didnt. This was for a quad. I tried as you said but I think it just erased my model memory when I selected 6 channel plane! Did it just reset everything as if if it was a new model?
Time to create page: 0.364 seconds
- need help with trim screen missing.
