Module Installation Guide for Devo 6?
13 Oct 2015 01:31 - 13 Oct 2015 02:04 #38769 by Arnold
I've looked around the Deviaton website, but didn't find a link to a guide for installing modules in the Devo 6. Did I miss it?
Last edit: 13 Oct 2015 02:04 by Arnold. Reason: Typo
13 Oct 2015 03:17 #38771 by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Module Installation Guide for Devo 6?
Haven't done it, but AFAIK it should be the same as any other devo TX (apart from the 7E), as it uses the same plug-in module ("8s" module)
13 Oct 2015 07:50 #38772 by mwm
Replied by mwm on topic Module Installation Guide for Devo 6?
RoGuE_StreaK wrote: Haven't done it, but AFAIK it should be the same as any other devo TX (apart from the 7E), as it uses the same plug-in module ("8s" module)
I have done it, and that is indeed the case. You have two sets of connections, one on the CYRF module, which is the same one used in the 8/10/12, and another to a the TMS/TCK/VCC/RST/GND points on the main board. Like the others, they are in a nice row suitable for installing headers on (which I recommend), and all labelled.
13 Oct 2015 18:29 #38775 by Arnold
Replied by Arnold on topic Module Installation Guide for Devo 6?
:cheer: That's good news - thanks, guys.
Time to create page: 0.061 seconds
