Flaperon programmation
10 Nov 2015 10:24 #39813 by TB34
Flaperon programmation was created by TB34
Hello everyone,
I have a devo 12s with deviationtx 4.0.1 and a glider with 3 servos per wing (1 for aileron, 1 for flap and 1 for airbrake).
I have no idea how to process the programmation of Flaperon mode using banking on stick and camber position on the FMOD 3 positions button
Does anyone have a solution or a tuto to help me?
Apologize my bad english, but I'm french.
Thank you all.
As I 'm new on this forum, I hope i'm writing in the right category.
Have nice flights
TB34
10 Nov 2015 13:59 #39823 by mwm
Replied by mwm on topic Flaperon programmation
Since it's fixed wing, you need to be using the advanced gui, not the standard one. Using those extra channels will require that in any case.
I wrote a tutorial on dealing with the advanced gui mixer programming that walks you through a relatively complicated setup for a quadcopter. It should at least get you started, thoug if you have really complex the interactions on the various flaps/brakes/etc. it won't get you all the way there: deviationtx.com/forum/how-to/3948-tutori...-a-model-config-file
10 Nov 2015 14:45 #39827 by TB34
Replied by TB34 on topic Flaperon programmation
Thank U MWM.
I 'll read this.
10 Nov 2015 18:19 #39844 by blackmoon
Replied by blackmoon on topic Flaperon programmation
Once you have read the tutorial, you can look at this model file for the Lanyu ASW28 glider by Birdman
Devo 8s Mode 2
ADIF Aileron differencial
E>F Elevator > Flap mixing
A>R Aileron > Rudder mix. R/DR sw
F>A Flap > Aileron mix. AIL/DR sw
F>E Flap > Elevator.
CROW Airbrakes. Gear sw
AIL.T Aileron Trim. Trims ailerons up/down together.
Flap1, Flap2. Mix1 Mix2 sw
A>F Aileron > Flap mix. ELE/DR sw
DFL.T Dual Flap Trim. R Trim. Trims flaps opposite to each other.
Flaps L Trim
Motor brake
12 Nov 2015 10:24 #39972 by TB34
Thank's for your hepl Blackmoon
Time to create page: 0.413 seconds
