stop prop timer
- SilbernerSurfer
22 Nov 2015 02:08 #40284
by SilbernerSurfer
stop prop timer was created by SilbernerSurfer
Hello together!
I want to configure a timer as stop-prop.
I have done this before but I have forgotten how it works.
It starts fast at -100% and gets slower or stops at 0% throttle. Then it gets faster at 100% throttle. I want to have it starting slow at -100% and getting faster up to 100% throttle.
As far as I remember I need a virtual switch.
Can someone help me out please!
Thanks in advance
Uwe
Thanks in advance
Uwe
22 Nov 2015 05:42 #40288
Replied by mwm on topic stop prop timer
use a virtual channel as the prop control channel. Src is your throttle channel (either stick or output, depending on what you want). Scale is -100.
- SilbernerSurfer
22 Nov 2015 12:21 - 22 Nov 2015 12:21 #40295
by SilbernerSurfer
Replied by SilbernerSurfer on topic stop prop timer
I cant get it working with scale -100.
I have used Virt1 as source at the stop-prop.
At the virtual switch I have:
Simple
Src: Thr
Curve: 1-to-1
Scale: -58
Offset: -58
It seems too work!
Would you kindly describe how I can set it up with Scale: -100 as you mentioned above?
Simple
Src: Thr
Curve: 1-to-1
Scale: -58
Offset: -58
It seems too work!
Last edit: 22 Nov 2015 12:21 by SilbernerSurfer.
Time to create page: 0.231 seconds
- stop prop timer
