Receiver connection devo 7e
06 Dec 2015 03:48 #40614 by Schear
Receiver connection devo 7e was created by Schear
Now that I updated the firmware on my devo 7e I can't get it to talk to my devo recievers. Is there something I'm missing here in the settings?
06 Dec 2015 04:17 #40615 by Deal57
Replied by Deal57 on topic Receiver connection devo 7e
You will need to bind again. If you have the current fixedID number, you may be able to use it, but it's easy to clear the current one. Once you clear the current FixedID you bind, then before your power off you can set the Fixed ID in the TX and you should be good to go.
I listed the bind process here, around step 3 or 4.
www.deviationtx.com/forum/6-general-disc...y-devo-10-dead#40464
Time to create page: 0.057 seconds
