- RX2702V using a DEVO 10 with Devention 4.01 issue
- Kunzer
08 Dec 2015 01:04 #40673
by Kunzer
RX2702V using a DEVO 10 with Devention 4.01 issue was created by Kunzer
I purchased a RX2702V to put into a 250 Trex clone. I wanted to test everything on the bench before installing it in the air frame. So i have a ESC (40amp), the 4 servos all digital, and the DEVO 10 set for the WK2801 protocol. plugged everything into the RX using Throttle 1 for the ESC. Set the radio settings as per the V450D01 manual. The receiver binds all the red LED's go out and i can move the servos. Issue is when i move the cyclic control left and right, the ELE and ALE move and the Pitch stays stationary. Moving the cyclic fore and aft the Pitch moves like the ELE should. I know the manual says to switch out the ALE and Pitch on a mode 2 TX setup but this isn't a reverse problem. Moving the ELE servo to the front left or right would be dumb or risky to even attempt. Im hoping there is a easy setting issue or maybe I have a defective receiver.
09 Dec 2015 16:19 #40755
Replied by hexfet on topic RX2702V using a DEVO 10 with Devention 4.01 issue
You may be seeing the problem described in
this issue
. The CCPM cyclic assignments for AIL and ELE are reversed, except for swashtype none. More details in the notes of the issue and the threads referenced there.
- Kunzer
11 Dec 2015 12:21 #40815
by Kunzer
Replied by Kunzer on topic RX2702V using a DEVO 10 with Devention 4.01 issue
Thank you for the info as it appears to me they didn't get far with it either. Ill install a RX2618VD which does work and try to sell the RX2702V since its useless to me now.
Time to create page: 0.196 seconds
